Fuel system architecture question (mechanical pump / filter)
Re: Fuel system architecture question (mechanical pump / filter)
So, maybe I missed how your tank is being vented?
On my high-tech gravity feed petcock motorcycle "pump" if the tank vent became clogged somehow ...
Edit: Just saw MadBill's mention.
Treed ya Kev!
Florida waters often have all sorts of nastiness blanketing them. It seems quite possible that even an emissions charcoal canister (tank vent system) could become clogged with growth. I have two turtle tanks and go through prodigious amount of activated charcoal which is promptly coated with algae. The [deposited/adsorbed vapor of the] fuel itself could be a growth medium.
I do not know the year of your magnificent Pantera boat -- does (cough -- did) it have emission controls originally?
https://www.offshoreonly.com/forums/gen ... ost3433378
https://patentimages.storage.googleapis ... 807160.pdf
Thanks for the replies.
The tank is vented with a 5/8” hose. It is clear.
I thought about a cracked pickup tube, so I pulled the tank fitting and put some air on the vent hose (a couple PSI) and was looking for some leakage around the half of the pickup tube that is not submerged. The column of fuel rises up the tube with no air leakage.
The boat is a 1977. I restored it from the hull up. It has a brand new Florida marine tank in it. (They made the original tank). As such, the entire boat and all the rigging is from scratch.
Thanks again for all the replies and help,
Rob
Rob
What happened when you put a brand new filter cartridge on? That would be the second one.
Ohio Rob wrote: ↑Wed Jul 01, 2020 6:20 am Thanks for the replies.
Rob
I just received a replacement element yesterday.
The element on the boat is the original. Boat has about 40 hours of run time on it.
Last night, I removed the filter from the circuit. I have the parts to move the filter to after the pump and mount it above the pump on the front of the cylinder head.
I’m waiting on a piece of 6061 3/8 plate to machine up a mounting bracket for it.
I figured I’d start the boat tonight with no filter, to rule out everything else.
I’m waiting on a plate of 6061 to machine up a bracket to mount the fuel filter on the cylinder head. I have some nylon spacers to isolate the Heat transfer.
I removed the filter out of the circuit completely and still could only muster 3 PSI of pressure. I pulled the Baker fuel pump (again) and disassembled it. This time I pressed the .250 pump arm fulcrum pin out of the body and discovered that a small bushing that rides on the pin was cracked in half. This let the pump arm fall in between the two halves and resulted in the stroke being cut in half.
Here’s a pic of the broken bushing
After trying to reach someone at Baker engineering with zero customer service, I bought a Holley fuel pump.
I called 4 times and was passed to an answering machine in the “tech” department. Left multiple messages and still haven’t received a return call or email.
Last call, I asked the receptionist if I could please speak to someone for just a few minutes so I could describe the broken bushing and buy a few to have on hand. Apparently, I’m the only guy who has ever had this problem (according to the lady who answers the phone) and I was Informed that they don’t sell replacement parts. I was told to box the pump up and send it off, and they would take a look when they had some time. She asked me to send photos of the broken part, and someone would call me. I sent the pics last week, and still no correspondence from Baker.
Needless to say, I was not happy with the complete lack of support.
I’ll never buy another Baker engineering product again. Not because it failed. I get that stuff breaks. I can’t deal with being run around and their lack of concern for my situation with their product.
Here’s the Holley pump.
Sorry to hear about the problems.
When you take your boat out are you running it off-shore or in inland lakes/rivers?
Did you (carefully) cut open the old fuel cartridge and check to see if it was plugged up with detritus?
I am just concerned about association and causation: root cause failure analysis generally. A pump could have infancy failure if overly stressed.
Being stuck adrift in the open ocean pondering this anew could be life-threatening.
The boat gets used on the west end of Lake Erie. I have marine towing insurance.Kevin Johnson wrote: ↑Tue Jul 07, 2020 11:09 pm Sorry to hear about the problems.
I didn’t cut the old filter open, but I did squirt fuel into the outer perimeter of the filter with a squirt bottle and it immediately transfers to the inside of the cartridge. I may cut it open and check, as I have a new element on hand.
Thanks for the reply
That's a much safer situation. Cell phones and beacons make a big difference nowadays.Ohio Rob wrote: ↑Wed Jul 08, 2020 5:45 am ...
In 1976 our family boat hit and rode up on the breakwater outside Calumet Harbor after the Bicentennial Fireworks. For some reason navigational lights had been turned off marking it. I had to use a flashlight to signal SOS to passing boats. Lake Erie used to be much worse but there have been significant algae blooms there recently and growth or contamination of fuel is a nationwide issue.
I was sitting facing the stern and suddenly the engine went into full reverse and lifted out of the water. Then BAM. Good times.
Glad you figured it out. I kinda figured that it wasn't your original filter setup.
On marine applications, is the vent on the fuel pump supposed to go into the intake tract?
Yes, that screened vent is screwed into an 1/8” NPT. I have a barbed 1/8”NPT fitting that I have a line on that terminates in the air cleaner base.
