Page 2 of 3
Re: Steel Main cap material
Posted: Sun Jul 05, 2020 4:13 am
by Exminiman
Kevin Johnson wrote: ↑Sun Jul 05, 2020 2:42 am
Exminiman wrote: ↑Sun Jul 05, 2020 2:04 am
Stock centre cap is suffering from some porosity, which I am concerned will start a stress crack
The crank is Forged EN40B steel which is quite stiff, I am concerned it will aggravate any shortcomings on main caps...
Maybe I am over thinking it.....
I do not think that you are over thinking it. You have identified a weak link. Trust your judgment.
For those who do not know, this is a three-main bearing crank.
Any pics of the new crank? Does it use dummy mains? Just curious as I made many parts for these engines.
This is actually a factory crank.....here are a few stock photos, saves me going out to workshop..
Posted: Sun Jul 05, 2020 7:51 am
by Kevin Johnson
Posted: Sun Jul 05, 2020 8:17 am
by ClassicComp
1018 hrs.
If you need them made pm me
Posted: Sun Jul 05, 2020 9:03 am
by BCjohnny
Almost any HRS structural grade will do, ask a local flame cutting shop for offcuts, they go in the scrap usually
If you're jobbing all the machine work out the actual cost of the steel is infinitesimal compared to all the other costs, so EN8 might make you fell better
If they're made accurately enough leave ~ 15-20 thou on the radius for align boring
Throw some 12.9 capscrews at it also
Posted: Mon Jul 06, 2020 8:48 am
by Exminiman
BCjohnny wrote: ↑Sun Jul 05, 2020 9:03 am
Thanks for this, its really useful, I was wondering about how much meat to leave for the inline boring, have a set of ARP studs (converting from bolts) but will need a couple more as will do as 4 bolt/stud.
I have seen the two extra studs/bolts inclined at about 10 degrees, is this worth it ? - top wack of the motor will be about 120BHP....
Posted: Mon Jul 06, 2020 9:06 am
by 4sfed
Unless you plan to make them yourself, you can buy a set from Mini Mania.
Posted: Mon Jul 06, 2020 7:07 pm
by Exminiman
4sfed wrote: ↑Mon Jul 06, 2020 9:06 am
Thanks, I did try them, my block is an early Thin flange block, which has slightly different bolt spacing on main caps, they sent me what they thought were right, but unfortunately not.
So, I am in process of making some.......
Posted: Tue Jul 07, 2020 4:01 am
by BCjohnny
For the amount of work you're investing anyway it's not going to hurt anything ..... although I doubt it's absolutely necessary
Good luck with it all
Posted: Tue Jul 07, 2020 6:52 am
by Kevin Johnson
BCjohnny wrote: ↑Tue Jul 07, 2020 4:01 am
Try to have a young interested lad or lassie there to learn some of this.
Posted: Fri Jul 10, 2020 1:51 am
by Exminiman
Thanks a lot for advice guys, not being a professional engine builder, just an enthusiastic amateur, I was a little hesitant with my first post, for no good reason, thanks again for making me feel welcome.
Posted: Sat Jul 11, 2020 9:21 pm
by MadBill
Exminiman wrote: ↑Sun Jul 05, 2020 2:04 am...
Just for general knowledge, all steels regardless of tensile strength have virtually the same stiffness (Young's Modulus)
Posted: Sun Nov 15, 2020 5:56 am
by Exminiman
Exminiman wrote: ↑Mon Jul 06, 2020 7:07 pm
Thanks, I did try them, my block is an early Thin flange block, which has slightly different dowel size, they sent me what they thought were right, but unfortunately not.
Posted: Sun Nov 15, 2020 10:07 pm
by MadBill
Making caps or making stepped dowels?
Posted: Sat Nov 21, 2020 6:30 pm
by Krooser
I applaud your efforts. Not many amateurs would attempt this on their own.
The little BMC engines have a spot in my heart. My older brother had a Morris Minor circa 1960 and he left me tools and instructions on how to dissemble the engine in preparation for a sorely needed valve regrind. At age 11 it was a fun project... hauling the head to the machine shop in my little red wagon and getting it reassembled before he came home from his out of town door to door vacuum cleaner sales job!
He ice raced the little Minor for a few years and beat a fair share of Vettes and other higher hp machines due to the obvious lack of HP that would not allow much wheel spin!
A winning crew chief at age 11... Have to put that on my resume.
Posted: Thu Nov 11, 2021 8:15 am
by jake197000
Vegas main caps ? the brune so much œil it didnt matter.they were a good smoking car though.by the tome the hard the problems fixes the killed it
