10.4:1 pump gas 316"
http://wright-here.net/files/articles/p ... bo_ocr.pdf
It looks like you were trying to lose weight in the rotating assembly on this build.gmrocket wrote: ↑Sun Jul 12, 2020 3:27 pm10.4:1 pump gas 316"
They were the piston sponsors that year and were willing to make me a custom 2618 to my specs and ring choice. It’s an oddball bore size,, so I had to take what they could makeRimmo wrote: ↑Mon Jul 13, 2020 12:44 amIt looks like you were trying to lose weight in the rotating assembly on this build.gmrocket wrote: ↑Sun Jul 12, 2020 3:27 pm10.4:1 pump gas 316"
What were your thoughts behind going with the Ross full round skirt piston versus a lighter slipper design?
Are they for some other application?
100mm over, whats the bore size then ?rocketracer380 wrote: ↑Sat Jul 18, 2020 7:19 pm can also use a 5.3 ls flattop in 100mm over with a 3.5 stroke and 6.250 rod makes for a budget shortblock
The small .980” pin bore without the bushing is about .994“rocketracer380 wrote: ↑Sun Aug 09, 2020 12:46 pm scat i beam rods remove bushing and press fit .980 pin i had to go with a.990 eagle might work with the .980
