Cheap SBC aluminum heads..
Post by pdq67 »
I had my Son order these for me.
https://www.ebay.com/itm/FOR-CHEVY-SMAL ... Swb2JbovTf
Total: $321.80
So I guess I will see how good they actually are.
Cheap enough because I can 't melt beer cans this cheap to pour a pair..
Alaskaracer
Re: Cheap SBC aluminum heads..
Post by Alaskaracer »
Be prepared to have about $1000 worth of work done to them to correct everything that's screwed up......There's a reason they are that cheap....
Mark Goulette
Authorized Amsoil Retailer
Post by pdq67 »
I'm expecting it so if it costs too much money, I will not refurbish them.
canuc
Post by canuc »
if you know a good down to earth shop get the guides checked for size the valve job right and blended into port load um with some decent parts and you should be good . let us know now they look when you get them , got to be pretty low qc at that price . somebody posted somewhere that casting is the same as the ching chong head afr is offering now ???
esahc
Post by esahc »
i spoke to a local shop that builds a fair amount of high performance small blocks. their position on them was sure, they are cheap, but by the time everything is corrected you will have almost a grand in them, and it is a 50/50 shot if the heat treat was done right. Also not good for power adder stuff due to thin decks.
He did say for a mild street combo they are not to bad, and definitely a better starting point than an old set of stock iron 461/462 heads, and they can be ported to get decent flow, the chambers are not bad. He said for their cost a better starting point would be a set of the new afr enforcer heads, at least you know they have good parts and the machining is better than average. He is not a dealer for any particular brand. just his experience with the cheap stuff that customers have brought him. it was an interesting conversation because the guy made it clear up front he would make more money off of the cheap heads vs going with a set of afr, trick flow, or rhs heads. and after he corrected everything the out of the box name brand heads would make more power, and in the end that is the way he steers his customers.
Alaskaracer
Some very common problems that have been found with those heads and similar are guides that aren't positioned correctly, loose fitting guides, poor machine work, loose or poorly installed seats, very cheap material used in the seats, etc....other times the port locations are off, port shapes are horrible........
There are head guys out there that buy the raw castings and can produce a very good head a a very reasonable price, but they too have horror stories of "fixing" cheap heads just to make them usable...
Mark Goulette
skinny z
Post by skinny z »
pdq67 wrote: Sat Jul 11, 2020 7:43 pm I had my Son order these for me.
I'd like to see how those stack up to these.
viewtopic.php?f=49&t=61584&p=869093#p869093
BOOT
Post by BOOT »
I looked at the ad and it has the ebay (100% buyer satisfaction) & says (FREE 30 day returns), so basically look them over well and if you find a issue or just don't like them start a return and you'll get a label(pretty sure free) to send them back. Your just out inspection time or cost basically.
Just got another set, it looks like these are prob the same as my 1st set with vortec ports and possibly larger 68cc chambers, I'd like to CC a chamber to see if they are 68 since I couldn't for the set I have with bad exh seats. If this set checks out, so far I'm 1/1 n this will be the tie breaker.
Bob Hollinshead
Post by Bob Hollinshead »
They look like the pro-comp speedmaster casting, I tried to use a pair on a 400 a few years back and there were two rocker studs on each head that were not located correctly-there was no easy way to correct it
Pro question poster.
Bob Hollinshead
Total: $321.80
Let us know how these work out.
Roundybout
Post by Roundybout »
I saw the $321 and change total and thought that was per head. :shock:
BOOT
Post by BOOT »
Bob Hollinshead wrote: Sun Jul 12, 2020 9:32 pm They look like the pro-comp speedmaster casting, I tried to use a pair on a 400 a few years back and there were two rocker studs on each head that were not located correctly-there was no easy way to correct it
They aren't I got a procomp I'm gonna make a video comparing the differences shortly
BOOT
Post by BOOT »
Roundybout wrote: Sun Jul 12, 2020 10:05 pm I saw the $321 and change total and thought that was per head. :shock:
Plus taxes. The last set I bought for my 2.0 video was $371 but they have more common intake flange ports and should be 64cc chambers
Bob Hollinshead
The size of the bowl doesn't leave much room to correct the shape unless a 2.05 or 2.08 valve can be installed, unknown what the short turn looks like. I would rather have a 180cc or 190cc port with room to make corrections
1980RS
Post by 1980RS »
Total: $321.80
Let me know what you think of them and how they look, I may be interested in getting a set too to see what I can do with them.
