Cam advice
cgarb
Cam advice
Post by cgarb »
Could I get some feedback on this cam choice please?
347 SBF
Bracket race 110 race gas 650hp carb Vic Jr intake
11.5-1 compression
AFR 185 heads
4000 stall speed C4 trans
4:30 rear/28" rear tire 3100lb mustang
Solid Roller
286/289 ;Duration @ .050 (Int/Exh): 255/258 ;Gross Valve Lift (Int/Exh): .642/.626 ;LSA/ICL: 106/102 ;Valve Lash (Int/Exh): .024/.026 ;RPM
PRH
Re: Cam advice
Post by PRH »
The thing that stands out to me with that overall combo is....... it has way less stall than I’d use.
novafornow
Re: Cam advice
Post by novafornow »
The thing that stands out to me is that it doesn’t look like a 650hp combination. If it is, you are a sharper dude than I am.🤷‍♂️
CamKing
Re: Cam advice
Post by CamKing »
That cam will peak HP around 7,000rpm, and would like more stall(4,500-4,800)
cgarb
Re: Cam advice
Post by cgarb »
So an 8" converter would be in order. I know this is not a 650hp combo. If this made 500, I would be perfectly happy. I was not trying to win engine masters. What about this camshaft? How would the two act differently? I have typically ran narrow LSA in the few Fords I have dealt with. Would the 110 with this cam do alright?
Advertised Duration (Int/Exh): 285/293 ;Duration @ .050 (Int/Exh): 255/263 ;Gross Valve Lift (Int/Exh): .640/.640 ;LSA/ICL: 110/104 ;Valve Lash (Int/Exh): .016/.016 ;RPM Range:
CamKing
Re: Cam advice
Post by CamKing »
cgarb wrote: Tue Jul 14, 2020 11:54 am Advertised Duration (Int/Exh): 285/293 ;Duration @ .050 (Int/Exh): 255/263 ;Gross Valve Lift (Int/Exh): .640/.640 ;LSA/ICL: 110/104 ;Valve Lash (Int/Exh): .016/.016 ;RPM Range:
This cam would move peak power up to about 7,400rpm, and need a 5,000 stall
6.50camaro
Re: Cam advice
Post by 6.50camaro »
novafornow wrote: Tue Jul 14, 2020 11:06 am The thing that stands out to me is that it doesn’t look like a 650hp combination. If it is, you are a sharper dude than I am.🤷‍♂️
I think he was refering to a 650 cfm HP style Holley carb not that it will make 650 hp . Dan
piston guy
Re: Cam advice
Post by piston guy »
4.86 gear , more stall, 750hp carb =10 second ETs . my similar 331 does but with a 5.29 gear and 8,000 in the lights.
cgarb
Re: Cam advice
Post by cgarb »
Camking,
The second camshaft, the Manufacturer said RPM Range: 3000-7500, the first cam was RPM Range: 4200-7200 which you were pretty much spot on with your analysis. That was why I asked what the second cam would do. Myself thinking, this is more duration and a wider LSA, how will this make the power range lower. You said just what I thought...peak power went up. So that cam in the car probably would make a slower et. In your opinion, would you go smaller yet or is the 1st cam a decent choice if I would up the stall speed? This engine will not get shifted higher the 7000 most likely, probably 6500/6800 range.
CamKing
Re: Cam advice
Post by CamKing »
cgarb wrote: Tue Jul 14, 2020 12:40 pm This engine will not get shifted higher the 7000 most likely, probably 6500/6800 range.
If you're not going to turn it over 7,000rpm, this is what I would recommend
Cam#, F351w, R73400-74406-106
247/251 @.050"
.400"/.406" Lobe Lift
106 LSA
This would also work well with your current stall speed/
BobbyB
Re: Cam advice
Post by BobbyB »
CamKing wrote: Tue Jul 14, 2020 1:33 pm
247/251 @.050"
106 LSA
Can you give a guess at the HP this combo will make Mike?
novafornow
Re: Cam advice
[/quote]
That’s what I get for reading right after I get up in the morning when my eyes are still blurry!
CamKing
Re: Cam advice
Post by CamKing »
BobbyB wrote: Tue Jul 14, 2020 1:52 pm
247/251 @.050"
106 LSA
530 @6,800rpm
cgarb
Re: Cam advice
Post by cgarb »
That would be plenty...lol. That would run real good in the Mustang.
