Lowbuck Shop/Race Truck Build
vortecpro
Re: Lowbuck Shop/Race Truck Build
Post by vortecpro » Mon Jul 27, 2020 7:53 am
Monza355 wrote:
Mon Jul 27, 2020 5:54 am
vortecpro wrote:
Sun Jul 26, 2020 7:42 pm
Monza355 wrote:
Sun Jul 26, 2020 6:58 am
Fantastic father and son project ! I saw the engine begin dynoed on youtube and it’s very stout ! What converter are you using behind it in the truck ? And what does a truck like this weight ?
ATI converter. Weight is 4000 pounds.
8” i assume ? It will be great to hear how it will do on the strip !
Its 8 inch. I have run 13.90 @ 100 MPH in Colorados 8000 plus DA air so far, but thats with the 3.07 gear, 2.17 60 foot :shock:. I think with tire rim change along the rear end change, we should have a different animal on our hands........I hope. One other thing I should mention is we have 17,000 miles on this truck since we built it.
77cruiser
Post by 77cruiser » Mon Jul 27, 2020 10:18 am
I had a spool like that 45 yrs. ago wasn't that purdy with the tig welds & all, just stuck some 7018 in there. :)
Jim
nxtruck
Post by nxtruck » Mon Jul 27, 2020 5:25 pm
vortecpro wrote:
Sun Jul 26, 2020 7:48 pm
nxtruck wrote:
Sun Jul 26, 2020 7:39 pm
Also, fwiw, I think your 12-bolt will be fine. My truck weighs 4000 with me in it and has been 1.45 60 fts. with the truck 12-bolt.
The 1985 Nhra Stock C-10 low compression 350 combination have run 11.90s with 1.47 60s @ 3800 and change. I will try a OEM 5 inch shaft, if that doesn't work I will put the super heavy factory 2 piece back in there that goes every direction but strait.
That is impressive for that low compression combo and at that weight. Your project sure sounds like a fun one. Have fun with it!
vortecpro
Post by vortecpro » Mon Jul 27, 2020 7:34 pm
1980RS wrote:
Mon Jul 27, 2020 12:56 am
Look at that young racer getting after it. Mark will have another winner in his stable soon. Keep us posted, always enjoy your builds.
Thanks
vortecpro
Thanks, it is fun........
FuelieNova
Post by FuelieNova » Mon Jul 27, 2020 8:11 pm
How old is your son? I love seeing father/son projects. Cant wait on my grandsons to get a little older.
Great job.
Tom
vortecpro
Post by vortecpro » Mon Jul 27, 2020 8:23 pm
Great job.
Tom
He's 15 and he's an engine kid!
vortecpro
Post by vortecpro » Wed Jul 29, 2020 8:03 am
Question: Did you run a OEM 5 inch drive shaft? My wifes truck has the same shaft and works fine, although its not turning 7000 RPM. Your thoughts.
nxtruck
Post by nxtruck » Wed Jul 29, 2020 11:45 am
No sir. The 1-piece that I ran was only 4”. It was a steel shaft, too. I don’t remember the length of it, but could find that out for you, as I still have it in the shop. I would have no problem running that shaft in a short wheelbase truck, but my experience with a 1-piece in my long wheelbase truck was less than stellar. Lol.
vortecpro
Post by vortecpro » Wed Jul 29, 2020 7:14 pm
Back in the late 90s I had a square body I built for a shop truck, long bed. I had a one piece steel shaft built for it locally, It did have a vibration at hi way speeds. I had another shop build me the same shaft, no vibration at hi way speeds, I feel I owe it to my self to try with the 5 inch OEM aluminum shaft. I do appreciate the advice though.
cgarb
Post by cgarb » Wed Jul 29, 2020 7:30 pm
An aluminum shaft will probably not shake. It has less weight than a steel shaft, the weight is what contributes to it wanting to whip some. Identical shaft diameters and lengths the aluminum will spin more rpm till it starts shaking than steel.
Post by F-BIRD'88 » Wed Jul 29, 2020 7:52 pm
2driveshafts are each shorter and stronger and each has a higher natural resonance frequency. And the engine and rear axle relative mounting angles can be bigger U joint running angle is more stable . unequal length supresses natural vibration transfer between the 2driveshafts.. You go farther for longer in a big truck.
vortecpro
Post by vortecpro » Sat Aug 01, 2020 10:34 pm
My rear end build came to a end today, unfortunately I will have to science out the rear suspension too use the new rear end, feels like its trying to pitch the drive shaft, pinion angle is wrong. If anyone has any ideas on how to make it work I'am open to suggestions.
cgarb
Post by cgarb » Sat Aug 01, 2020 11:05 pm
I assume there is too much pinion angle? Can you use the wedge type pinion angle spacers to work it out?
nxtruck
Post by nxtruck » Sun Aug 02, 2020 1:22 pm
X2. I, too, would be looking at those wedge shims. Were the spring perches in the factory location? Is this the factory rearend housing? If so, I would think things would be fairly close, unless the truck has been lowered several inches.
