Question about 100% water injection
exhaustgases
Re: Question about 100% water injection
Post by exhaustgases » Tue Jul 28, 2020 11:49 pm
Sounds like they need to be made from Inconel.
Roy
Post by Roy » Wed Jul 29, 2020 7:22 am
Nozzles are mounted in the intake horn above the manifold, so the only heat they see is whatever the charge air cooler doesn't remove and normal engine bay heat. I really need to figure out how to put up pictures.
Roy
Post by Roy » Wed Jul 29, 2020 8:01 am
Please excuse the rats nest of wiring and plumbing. Much of this system is made of cheap components which I am still testing, so i did not tidy up yet. Plus I have been swapping lines around trying nozzles.
This shows a very active area. In the back is the main supply manifold, 1/2 nylon line feeding 4 1/4 outlet lines (1 spare in case I decide to add a 4th stage at WOT) In the front is the boost reference manifold which has all of my pressure switches, 5/10/20 psi.
Cheapie water valves rated for 140psi (they stick with anything more.. did NOT know that at the time of purchase) $10/ea amazon.
RV 8 gallon pottable water tank $50 including shipping wrapped in an old curtain for rub protection , and the mount I made from some scrap angle iron (why use good stuff? I use that on paying jobs!) Plus the 1.1 GPH@80psi ($35) pump which i turned up to 120 psi (It will go to 175 but my valves stuck :evil: ) you can also just barely see another valve to the left of the tank. When power is shut off to the system (which is tied in to the ecm ign+ power supply fuse) this valve opens (normally open, power to close) bleeding all pressure from the system back to the tank. This is a failsafe in case the relay feeding the pump decides to stick at key off (relay signal+ comes from ecm ign+, ecm ign+ is directly hooked to this valve.) Obviously we don't want to find out a valve leaked overnight and filled the intake up.
The ugliest part of the system currently, this side is truly under development. RV water filter made by camco used as a pre-filter for the reverse osmosis filter above it. My plan is to use a garden hose to fill the tank, thus making any mpg gains close to free (otherwise what little gains there are would be useless)
I am currently waiting for a .5L rv accumulator to show up in the mail to add to the pressure side. The pump is cycling so much that its doing all kinds of bad things. But thats because I have found you can inject a LOT more water than I thought. Stage 1 started as 60ml/min and is now up to 275ml/min. Stage 2 is 175ml/min. Stage 3 is using my original stage 1 nozzle, 60 ml/min. I need to purchase more but I want to iron out the issues first. Next I am going to run both the 275 and the 60 together for stage 1and see if it quenches out.
Roy
Post by Roy » Wed Jul 29, 2020 9:02 am
That is my largest nozzle (275) which I am currenly using for stage 1, just plugged almost solid on my way to the shop. Distilled water is out as the solution. Next is water soluble cutting oil.
Roy
Post by Roy » Sat Aug 01, 2020 8:49 am
Initial mpg results are in.
100-120psi supply pressure, snow performance nozzles, 5/10/20psi
Baseline 18.6mpg
Stage 1 60ml
Stage 2 175ml
Stage 3 275ml
18 mpg
EGT reduction 50-150F on the road.
Stage 1 175ml
Stage 2 275ml
Stage 3 turned off
17.6 mpg
EGT reduction 150-300F on the road.
Will update on water soluble oil in a few more days. Hasn't plugged in 2 days
Kevin Johnson
Post by Kevin Johnson » Sat Aug 01, 2020 10:02 am
It sounds like your injection system had some contamination that was not completely flushed out.
If you like reading FDA documentation, here is a start: https://www.fda.gov/inspections-complia ... system-793
Many of my chemical compounding customers had issues with biological growth from their water supplies which were also the source of their distilled water operations for blending.
https://www.sierrasprings.com/files/non ... 022417.pdf
Table 3 appears to show what contaminant levels the FDA has established for "distilled water" and your chosen supplier may meet them to a lesser or greater degree.
