GT45 Turbo For Dummies
Orr89rocz
Re: GT45 Turbo For Dummies
Post by Orr89rocz » Wed Jul 29, 2020 7:51 am
Gt35 is way to big and wouldnt spool well imo. I dont know much on corvair engines tho, how much rpm they can turn. That sized turbo on late model 4 cyl cars make many hundreds of hp. But can be a touch laggy. A good 61-62 mm compressor wheel can make 800 hp on a small engine. That turbine size 62/67 mm or so is a size that would be better on a higher rpm higher base hp 4-6 cylinder imo. It be ok if you had a built engine that could handle 400-700 hp or so.
The Californian
Post by The Californian » Wed Jul 29, 2020 10:13 am
Thanks Orr89rocz
'how much rpm they can turn'
I would say 5500-6000 RPM.
Corvair engine would be what we can run and test turbos on right now.
What about the T3/T4 Hybrid Ebay $100 turbo on the stock 80hp Corvair engine?
Found out from watching a few 'Unboxing Ebay Turbos' Youtubes to ask sellers if it is a Max Speeding Rods turbo.
Have found a couple of the T3/T4 turbos and they have offered a little off and say two year warranty.
Duct tape.It has a 1,000 uses.
Powered by Rockauto Parts.
Orr89rocz
Post by Orr89rocz » Wed Jul 29, 2020 10:57 am
T3/t4 T04e .57 Ar may be ok to try
The Californian
Post by The Californian » Wed Jul 29, 2020 11:00 am
Cool.
Okay.Then that is the plan.
Be neat to put all the gauges on it and see what is going on.
Litlle Corvair engine on a test stand and T3/T4 turbo.
Good thing about test stands and Corvairs is they are air cooled.No muss no fuss!
