Metal Clad Valve Seal Question
Posted: Wed Jul 29, 2020 10:29 am
What's the deal with the two types of metal clad seals, bare metal inside or viton(FKM) coated inside?
I got the wrong seals for my current heads, well actually I got the wrong tool to cut the guides. Can't find it atm but pretty sure it was suppose to cut to .500 but they are .494-.495. So the comp 517-16 seals(bare metal inside) will just pull off the six .494 guides. The .495 guides a seal took some effort to press on with my hand but had to use a tool to remove it. Suppose I could use some sleeve retaining compound on the .494 guides but in my research I found an old speedtalk thread with a site that has seals with the viton inside. Does the viton inside make them fit a wider range of guide?
Also I know comp has a seal 506-16 for a .494 guide, I'd bet my tool was mixed up or just poor quality if I could find it.
Anyways I'd prefer to get ones that fit instead of lock the seal on there. Also prefer the non comp-cam ones cause they have a better deal if they would work , these are two that may work
https://ussealparts.com/vs-108v-50-packs.html
https://ussealparts.com/vs-107v-50-pack.html
