How big can it go?
Posted: Fri Jul 31, 2020 10:19 am
Guy dropped off a BBC block casting 3999289 It had valvetrain issues that is why he took it out. He bought a used drag car and the engine backfired on the first pass and died. Broke rocker studs, bent push rods, etc. So I don't have a history on how many runs it has. The block cleaned up nice and the cylinders have no wear, block is filled, my issue is that it has a bore of 4.370 if I do the math right that is .125 over. I have a digital long reach caliper, and through the water jacket holes at the top of the deck it measures from .270 to .220 cylinder thickness. And from my experience between the water jackets is where they are thin most of the time. I have never had a filled block sonic checked, will it still be accurate with the fill? And a shop that has one is a couple hours away. How big can a BBC go? I get nervous at .070 over.
I am trying to talk the guy into an aftermarket block, options would be a dart sportsman or a merlin, looking at the specs, I don't see a big difference between the two blocks, any opinions?
He wants a 750HP to 800HP power level, it has Brodix BB-2 heads, and a flying toilet on alcohol. so I think that is easily doable.
