Roller lifters
408 Nova
Roller lifters
Post by 408 Nova » Fri Jul 31, 2020 2:34 pm
Is the main advantage of larger diameter lifters to help with pressure angles and block wear?
Getting a block drilled for the SB2.2 lifter pattern and would really like to know what diameter lifter is best to go with, with the .903" being as big as I would ever go.
And all that being said, what brand lifter is everyone using?
mt-engines
Re: Roller lifters
Post by mt-engines » Sat Aug 01, 2020 4:23 pm
go .937 with an .850 wheel if you can.
mt-engines
Re: Roller lifters
Post by mt-engines » Sat Aug 01, 2020 4:25 pm
jesel or morel makes nice keyway lifters. crower enduramax are nice, isky redzone etc
CamKing
Re: Roller lifters
Post by CamKing » Sat Aug 01, 2020 10:27 pm
The main advantage of a larger diameter roller lifter, is the larger diameter wheel that you can fit on it. The larger diameter wheel, produces less side loading on the lifter.
We have plenty of lifter options.
Our .842" and .875" lifters have .750" wheels.
Our .904" lifters have .810" wheels.
Our .937" lifters have ..850" wheels.
Our lifters can be upgraded to bronze bushings, or our steel-on-steel bushingless wheels
bob460
Re: Roller lifters
Post by bob460 » Sun Aug 02, 2020 12:20 am
Mike anyone running your steel on steel lifters on the street?...........if so how many miles.
bob460
Re: Roller lifters
Post by bob460 » Sun Aug 02, 2020 12:23 am
Bam is also a good lifter!
CamKing
Re: Roller lifters
Post by CamKing » Mon Aug 03, 2020 10:51 am
Yes, I have a customer that builds a lot of turbo street engines, and he's been using them for a couple years, I don't know how many miles they're putting on them, but we haven't had any issues.
