Roller lifters
408 Nova
Roller lifters
Post by 408 Nova »
Is the main advantage of larger diameter lifters to help with pressure angles and block wear?
Getting a block drilled for the SB2.2 lifter pattern and would really like to know what diameter lifter is best to go with, with the .903" being as big as I would ever go.
And all that being said, what brand lifter is everyone using?
mt-engines
Re: Roller lifters
Post by mt-engines »
go .937 with an .850 wheel if you can.
mt-engines
Re: Roller lifters
408 Nova wrote: Fri Jul 31, 2020 2:34 pm Is the main advantage of larger diameter lifters to help with pressure angles and block wear?
jesel or morel makes nice keyway lifters. crower enduramax are nice, isky redzone etc
CamKing
Re: Roller lifters
Post by CamKing »
The main advantage of a larger diameter roller lifter, is the larger diameter wheel that you can fit on it. The larger diameter wheel, produces less side loading on the lifter.
We have plenty of lifter options.
Our .842" and .875" lifters have .750" wheels.
Our .904" lifters have .810" wheels.
Our .937" lifters have ..850" wheels.
Our lifters can be upgraded to bronze bushings, or our steel-on-steel bushingless wheels
bob460
Re: Roller lifters
Post by bob460 »
CamKing wrote: Sat Aug 01, 2020 10:27 pm The main advantage of a larger diameter roller lifter, is the larger diameter wheel that you can fit on it. The larger diameter wheel, produces less side loading on the lifter.
Mike anyone running your steel on steel lifters on the street?...........if so how many miles.
bob460
Re: Roller lifters
Post by bob460 »
mt-engines wrote: Sat Aug 01, 2020 4:25 pm
Bam is also a good lifter!
CamKing
Re: Roller lifters
Post by CamKing »
bob460 wrote: Sun Aug 02, 2020 12:20 am
Yes, I have a customer that builds a lot of turbo street engines, and he's been using them for a couple years, I don't know how many miles they're putting on them, but we haven't had any issues.
Krooser
Re: Roller lifters
Post by Krooser »
Will going to a larger wheel change the cam performance?
panic
Re: Roller lifters
Post by panic »
It will tend to stretch the window at both ends of the duration.
CamKing
Re: Roller lifters
Post by CamKing »
Krooser wrote: Mon Aug 03, 2020 2:13 pm Will going to a larger wheel change the cam performance?
There would be a very small change in performance.
Using my 262@.050", .440" lobe lift profile
If you went from a .750" wheel, to a .810" wheel, here's how the durations would change
@ .012": +0.66 degrees
@ .050": +1.22 degrees
@ .100": +1.42 degrees
@ .200": +1.38 degrees
@ .300": +1.05 degrees
@ .400": +0.60 degrees
If you went from a .750" wheel, to a .850" wheel, here's how the durations would change
@ .012": +0.80 degrees
@ .050": +1.79 degrees
@ .100": +2.29 degrees
@ .200": +2.23 degrees
@ .300": +1.69 degrees
@ .400": +0.91 degrees
rebelyell
Re: Roller lifters
Post by rebelyell »
Mike
thanks Is it true that OE GM rollers (L31 & LS) have a wheel that's only 0.700" diameter ?
