Dart 215 SBC Heads Potential
I picked up a set of Dart 215's SBC for a song this week as the guy who had them on his 355 was really disappointed with them. I can see why as the heads are not meant for a mild hyd engine. They only had 500 miles on them but my question is on a 406 type engine what power potential do these heads have over lets say a Sportsman II 200cc head and can you really make some good power with these out of the box?
Re: Dart 215 SBC Heads Potential
i think they are one of the worst Heads out-the-box ,1980RS wrote: ↑Sat Aug 15, 2020 11:57 am I picked up a set of Dart 215's SBC for a song this week as the guy who had them on his 355 was really disappointed with them. I can see why as the heads are not meant for a mild hyd engine. They only had 500 miles on them but my question is on a 406 type engine what power potential do these heads have over lets say a Sportsman II 200cc head and can you really make some good power with these out of the box?
but there's a whole bunch of HP potential
waiting for you in those Heads .
i Dyno tested an early pair of Dart 215cc out-the-box
and from memory , was only 487 Peak HP ,
i think this was a 406cid .
the Dart Pro 1 215 or 230cc Heads are not that great out-the-box
but they end up one of the best Heads to use for maximum HP
if you Port them correctly .
Chevy Beretta 2450 Lbs runs 8.39 ET 162+ MPH ( all Motor HP , no NOS runs )
with Dart Pro 1 215cc Ported to 245Cc Int Ports
4.187x4.000=440.6cid
Peak TQ = 589.3 @ 6600
Peak HP = 807.5 @ 8300
600 rpm/sec
on old TV show "Passtime"
it ran
60 FT= 1.089
330 Ft= 3.110
660 Ft= 4.797 - 145.83 MPH
1000 Ft= 6.251
1320 Ft= 7.493 at 186.36 MPH
4.30 gear
2450 lb
325. Nos
later made 816 Peak HP @ 8200 RPM
ran 8.28 ET in killer Air, all Motor
viewtopic.php?p=707615#p707615
An old three part thread I did which could be helpful. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
If cast iron 215 are they "platinum series" ? or pre platinum heads (older) ?
Don’t write off your sportsman 2 heads. When ported correctly they can make power and go fast. I have done a few sets that make 650-660hp1980RS wrote: ↑Sat Aug 15, 2020 11:57 am I picked up a set of Dart 215's SBC for a song this week as the guy who had them on his 355 was really disappointed with them. I can see why as the heads are not meant for a mild hyd engine. They only had 500 miles on them but my question is on a 406 type engine what power potential do these heads have over lets say a Sportsman II 200cc head and can you really make some good power with these out of the box?
I have had good luck with both set of Sportsman II heads I have had but what's really funny when my 062 Vortec heads outshine the Sportsman heads that are ported and with less cam and compression. After reading what maxrace did with the Dart 215's there is some real power there after they are done right.MELWAY wrote: ↑Sun Aug 16, 2020 1:38 amDon’t write off your sportsman 2 heads. When ported correctly they can make power and go fast. I have done a few sets that make 650-660hp1980RS wrote: ↑Sat Aug 15, 2020 11:57 am I picked up a set of Dart 215's SBC for a song this week as the guy who had them on his 355 was really disappointed with them. I can see why as the heads are not meant for a mild hyd engine. They only had 500 miles on them but my question is on a 406 type engine what power potential do these heads have over lets say a Sportsman II 200cc head and can you really make some good power with these out of the box?
like MELWAY , i also made in the 650 HP range with Sportsman II cast-iron Heads !1980RS wrote: ↑Sun Aug 16, 2020 12:09 pmI have had good luck with both set of Sportsman II heads I have had but what's really funny when my 062 Vortec heads outshine the Sportsman heads that are ported and with less cam and compression. After reading what maxrace did with the Dart 215's there is some real power there after they are done right.MELWAY wrote: ↑Sun Aug 16, 2020 1:38 amDon’t write off your sportsman 2 heads. When ported correctly they can make power and go fast. I have done a few sets that make 650-660hp1980RS wrote: ↑Sat Aug 15, 2020 11:57 am I picked up a set of Dart 215's SBC for a song this week as the guy who had them on his 355 was really disappointed with them. I can see why as the heads are not meant for a mild hyd engine. They only had 500 miles on them but my question is on a 406 type engine what power potential do these heads have over lets say a Sportsman II 200cc head and can you really make some good power with these out of the box?
Brodix Track 1 also have a ton of HP potential , not so great out-the-box HP ,
i grind my best Dart Pro 1 intake port shape into the Brodix Track 1,
and on 2 identical SBC 442cid , the Track 1 and Dart Pro 1 were within 1 HP of each other = 816.0 @8200-8300 RPM
Larry, what CSA are these?maxracesoftware wrote: ↑Sun Aug 16, 2020 1:48 pm i grind my best Dart Pro 1 intake port shape into the Brodix Track 1,
Thanks
Mike R
this example simulation file is included in PipeMax v4.50pastry_chef wrote: ↑Sun Aug 16, 2020 5:22 pmLarry, what CSA are these?maxracesoftware wrote: ↑Sun Aug 16, 2020 1:48 pm i grind my best Dart Pro 1 intake port shape into the Brodix Track 1,
Thanks
Chevy_SBC442cid_8200RPM_815.8HP_6500RPM_578.1TQ_DartPro1_23deg.PMW
5.62500 Int Port Length / 3.10300 Exh Port Length
285.0FPS 2.65263 CSA 244.5CC 315.0000 CFM = User's Intake Port Flow at 0.866000 Valve Lift
285.0FPS 1.97726 CSA 100.5CC 234.8000 CFM = User's Exhaust Port Flow at 0.813000 Valve Lift
the same file has all the Flow numbers, Cam Specs , Engine build specs., etc
