msd box
chevy art
msd box
Post by chevy art »
just got my buddies car all wired up and plumed and is starts sometimes and sometimes it wont(just keeps cranking) and sometimes it just cuts out for no reason. its and old style msd 6 box. does it sound like box is defective. dont seem like it is the coil., any ideas to test this system thanks ar
1980RS
Re: msd box
Post by 1980RS »
chevy art wrote: Tue Aug 18, 2020 1:07 pm just got my buddies car all wired up and plumed and is starts sometimes and sometimes it wont(just keeps cranking) and sometimes it just cuts out for no reason. its and old style msd 6 box. does it sound like box is defective. dont seem like it is the coil., any ideas to test this system thanks ar
If you go on youtube there are videos to help test those boxes. I switched out my 6AL last year to a 7AL2 and it's night and day difference in spark output, for my car anyway.
Lizardracing
Re: msd box
Post by Lizardracing »
What Dist?
If an HEI I would suspect the reluctor.
If an MSD I would suspect the reluctor even more.
IF it's an MSD dist, testing those boxes is as easy as lining up the rotor with any tower and unplugging the connector and listening for the box chirping. Chirps its ok. No chirp it's not okay.
If it's the HEI, you'll unplug the connector and jumper across and listen for the chirp.
Schurkey
Re: msd box
Post by Schurkey »
Lizardracing wrote: Tue Aug 18, 2020 5:14 pm What Dist?
Reluctor??? Do you mean "Pickup coil"?
Lizardracing
Re: msd box
Schurkey wrote: Tue Aug 18, 2020 7:00 pm
Yes. They are easy to test. Your looking for AC voltage when cranking. Sometimes they won't generate voltage at slow RPM like cranking but will above that. Sometimes they are just cantankerous is general.
dannobee
Re: msd box
Post by dannobee »
If you think the pickup coil is bad, the easy peasy way to check is to put your old school soldering gun near the distributor cap and pull the trigger with the ignition on and listen for the ignition system zapping away. If it spits lightning, the pickup coil is bad. If it doesn't, look somewhere else.
But first things first, does the tach bounce when you're cranking it? If it comes off the zero mark when cranking, the primary side is good.
MSD boxes did fail quite regularly. Why do you think we kept two of them on circle track cars, with a switch for "plan B."
Lizardracing
Re: msd box
To be fair it's pretty common for these things to not be wired up very good. Poor grounds, low battery voltage, unsoldered wires, washed every week, heat soaked, vibrations etc.
Schurkey
Re: msd box
Post by Schurkey »
dannobee wrote: Tue Aug 18, 2020 10:35 pm If you think the pickup coil is bad, the easy peasy way to check is to put your old school soldering gun near the distributor cap and pull the trigger with the ignition on and listen for the ignition system zapping away. If it spits lightning, the pickup coil is bad. If it doesn't, look somewhere else.
If the pickup coil is GOOD, the soldering gun will induce AC voltage into the pickup coil, which triggers the module as the voltage goes from positive to negative--which fires the coil, "spitting lightning".
If the pickup coil is BAD, the soldering iron doesn't induce voltage--or the voltage signal isn't delivered to the module due to broken or grounded wire(s), and there's NO sparks.
This doesn't work with a too-small soldering gun. Mine is 450 watts. I haven't tried with a 200--250 watt gun.
BlitzA64
Re: msd box
Post by BlitzA64 »
I had one do that, it was a faulty rotor sometimes grounding the spark to the distributor through the rivet
Camaromeo
Re: msd box
Post by Camaromeo »
Sounds like grounds problems. Check every single cable at every single inch for problems.. Make sure ground is good.
