can this make 520 hp?
1980RS
Re: can this make 520 hp?
Post by 1980RS »
If that SBC doesn't make 520hp I'd drop it in the river. :lol:
skinny z
Post by skinny z »
DCal wrote: Wed May 25, 2022 10:49 pm Apparently it can. It made 553hp and 531tq. The small cam seemed to be the limiting factor as expected, but should provide the vacuum I need along with the Air Gap and 780vs 3310 and be a nice street engine. Thanks to everyone who helped with advice.
Is that with an unmodified Air Gap? Any carb spacer used?
What were the final cam specs?
Hope you don't mind the barrage of questions.
This may provide even more insight for another SBC that's in the works.
Thanks.
Kevin
DCal
Post by DCal »
Thanks.
The manifold was port matched which probably did nothing.
The cam : 233/236 @ .050, .583/.562, 109 in at 105
Sorry I forgot, it had a 1 inch open spacer for all the pulls because that's the way it will be in the car..
RevTheory
Post by RevTheory »
That'll be a street stomper, for sure. Where (rpm) did it peak hp?
DCal
Post by DCal »
RevTheory wrote: Fri May 27, 2022 6:34 am That'll be a street stomper, for sure. Where (rpm) did it peak hp?
It was done at 6100 and then was almost perfectly flat until 6400 where we had been stopping the pulls.
