Nitrous Softening
BobbyB
Nitrous Softening
Post by BobbyB »
Looking for ideas on how best to avoid wheelspin with a small nitrous shot.(100 hp or less on a 420 hp NA engine.) The car is pretty much has all the traction I can get it, and does well NA, so, unless the N2O comes on gently, it will spin.
I would like to avoid using a laptop if I can. That is what I have been using and would prefer not going back there. (My current progressive system has died as far as I can tell.)
I am considering adding volume between the nitrous noid and the plate to soften the hit. Has anyone seen this (or anything else) work really well?
mt-engines
Re: Nitrous Softening
Post by mt-engines »
BobbyB wrote: Mon Aug 24, 2020 2:24 pm Looking for ideas on how best to avoid wheelspin with a small nitrous shot.(100 hp or less on a 420 hp NA engine.) The car is pretty much has all the traction I can get it, and does well NA, so, unless the N2O comes on gently, it will spin.
fix the suspension. tighten the rebound
Monza355
Post by Monza355 »
Put it on a handheld button and spray when the tire has been planted
GARY C
Post by GARY C »
You would need a really long line to see any difference.
I have used this cheap delay timer with good success, usually 4 to 6 tenths of a delay will give the chassis a chance to set and hold the hit.
"This unit features plug-in fuse and 40-amp relay along with an adjustable 0.1 second to 1.0 second time delay in 0.1 second increments."
https://www.jegs.com/i/ARC-Auto-Rod-Con ... 2/10002/-1
lefty o
Post by lefty o »
a progressive timer is what you seek.
BobbyB
Post by BobbyB »
GARY C wrote: Mon Aug 24, 2020 4:01 pm
Thank you very much Gary!
fastblackracing
Post by fastblackracing »
We have had good results using the NOS mini controler for pulling power at the hit.
% setting, time setting and some pulse frequency adjustment.(Hertz)
Straight forward and not overly complicated.
GARY C
Post by GARY C »
BobbyB wrote: Mon Aug 24, 2020 5:11 pm
If you have a timing retard you could buy 2, get creative and use one to control the timing, they can be used as an on or off switch.
