Sleeve Flange To Counterbore Clearance?
When boring a block to fit a flanged sleeve, how much clearance is desired /acceptable for the sleeve flange to counterbore? The particular block has a 3.583 nominal diameter bore. Oil cooled diesel. Thanks.
Re: Sleeve Flange To Counterbore Clearance?
The manufacturer of the sleeve your using should be consulted on this question.
Some. I give them .004" total (.002" per side).
"do it right or do it right away"
http://www.motionmachineinc.com/
https://www.youtube.com/watch?v=ZgIZbveknDs
I agree,
"a few thou per side" is exactly what came to mind.
Unless there is a specified # I've always used .005 or .0025 per side.
Tom
Tom
