Piston pin bushings
Piston pin bushings
Uccrb980 pin bushings for ls rods are these meant to be used in ls bushes rods to utilize .927 pins any body ever use them?
Re: Piston pin bushings
The best way to do this is confirm the center to center length of the rods 1st.rocketracer380 wrote: ↑Tue Aug 25, 2020 7:38 pm Uccrb980 pin bushings for ls rods are these meant to be used in ls bushes rods to utilize .927 pins any body ever use them?
They call precision performance products center and get the correct bushing for the job.
That way if you need to bore the small end to correct length you will have the right bushings for the job.
If this is a stock rod project its less money to buy a set of new rods and carry on rather then the brain damage of bushing stock rods and correcting the length at the same time.
