Carb selection question
ClassAct
Re: Carb selection question
Post by ClassAct »
F-BIRD'88 wrote: Thu Aug 27, 2020 7:17 pm This is not true... If you primarily street drive your car VS drag race it you are better off with plenum heat in the long run. Can' determine if you are wasting your time. Seems you suspect that.
Been doing it since 1980, and not one time have I had to fatten up the idle with a cold air intake. In fact, the opposite is true. You take fuel AWAY. I’m getting ready to fire a 12:1 pump gas tunnel ram engine on Saturday. The tune up I put in the carbs is significantly leaner than what came in the carbs, which is 2 Quick Fuel Brawler 750’s.
It will run in sub freezing weather, and do it very well.
Ohio Rob
Post by Ohio Rob »
So, I think I’m going with the Holley 950 HP.
Thanks for all the replies fellas.
I’ll report back with some results and probably some tuning questions.
BradH
Post by BradH »
PRH
Post by PRH »
I would go with either a Holley 0-82951SA or a Brawler BR-67201
There are some funny comments about the Holley SD Mopar 440 manifold in this thread.
Still one of the best overall high performance intakes made for std port heads.
BradH
Post by BradH »
PRH wrote: Fri Aug 28, 2020 10:45 am I would go with... a Brawler BR-67201
If the OP hadn't specified "I want a dichromate finish, traditional type carb", I'd agree.
PRH
Post by PRH »
I guess I overlooked that detail.
BradH
Post by BradH »
BradH wrote: Wed Aug 26, 2020 11:48 pm Holley sells their factory refurb 80496s for about $550 if they are still available.
Just checked out of curiosity, but Holley's web site says none currently available. Too bad, cuz the "regular" price for a new 80496 is... uhhhh... pretty freakin' high, IMO. :shock:
Ohio Rob
Post by Ohio Rob »
BradH wrote: Fri Aug 28, 2020 11:09 am
I hear ya. I checked after you suggested that the other day.
Thanks
PRH
Post by PRH »
I guess I’ll take the weight reduction of the brawler type carb........ and save the $278 that goes along with it.
Since the shift in manufacturing has moved from the zinc castings to aluminum bodies and bowls, along with billet metering blocks and baseplates....... if the quality of the zinc parts are as good ever.
Plus...... no worries about “zinc pest” happening with the aluminum stuff.
Edit-I just did a google search for “zinc pest”, which used to have tons of images pop up of Holley carbs that had severe cases of it. Now....... you get nothing but model train pics.
So much for things being on the ‘net forever.
Ohio Rob
Post by Ohio Rob »
PRH wrote: Fri Aug 28, 2020 11:29 am I guess I’ll take the weight reduction of the brawler type carb........ and save the $278 that goes along with it.
I’m stuck on a dichromate finish and old school appearance.
I did have an ethanol / zinc ordeal on a marine carb, years ago. Now, I dry the carbs and bring them in the basement for off season storage.
My car is a “day 2” type muscle car. Check out how I removed the “Holley” off the SD
cgarb wrote: Thu Aug 27, 2020 5:26 pm
F-BIRD'88 wrote: Thu Aug 27, 2020 4:59 pm You have tune the idle circuit richer and the primary jet richer when running a cold manifold... Fuel vapourization requires HEAT INPUT.. You get BETTER vapourization around town with a little added plenum heat.
Thats why every OEM uses intake plenum heat.
The exhaust is cleaner. The plugs last longer. You get better fuel mileage. And don't stink up the air with unburned hydrocarbons. The engine will last longer too.
The OEMS know about street tuning better than you do.
Try it.
What if he wanted to run a tunnel ram? How would someone get good street tunability with that? How do you heat that intake.
Good point.. For street driving with a tunnel ram it wood be great if the plenum was heated to aid fuel vapourization.
(electric, hot water, hot exhaust heat duct) Current cast tunnel rams are made for racing but adding retro fitting for (controlled) manifold plenum heat will really work great on any street use tunnel ram induction car. Only needs creative engineering and some plumbing too employ that on your tunnel ram.. There are a few ways to skin that cat.
Here is what Chrysler did on the ram manifolds of the day to heat the carb plenums.
https://www.macsmotorcitygarage.com/wp- ... 36x300.jpg
Powertrip
Post by Powertrip »
[/quote]
I did the exact same thing, looks great!
Try it.
You'll be the first to know when I perfect the bolt-on electric/steam powered under carb, heated spacer plates. 🤓
Unless you do it first👍
BradH
Post by BradH »
So, you guys are saying that I can grind the "Trick Flow" logo off my intake and everyone will think my engine is stock? :lol:
lefty o
Post by lefty o »
BradH wrote: Fri Aug 28, 2020 2:23 pm So, you guys are saying that I can grind the "Trick Flow" logo off my intake and everyone will think my engine is stock? :lol:
you'll have to spray more paint on it though! 8)
