Stock Eliminator secrets?
novadude
Re: Stock Eliminator secrets?
Post by novadude »
A semi-related question.... Since we are talking 275/327 stocker combos....
Is the '69 LM1 255hp 350 still a popular combo for stock class racing? Seems like this engine has a pretty favorable hp rating (unless NHRA applies a correction factor).
vortecpro
Post by vortecpro »
novadude wrote: Tue Sep 29, 2020 5:12 pm A semi-related question.... Since we are talking 275/327 stocker combos....
YES YES YES YES
vortecpro
Post by vortecpro »
vortecpro wrote: Tue Sep 29, 2020 7:25 pm
YES YES YES YES the 441 head was the best flowing production early small block head ever cast, in NHRA trim.
Post by pdq67 »
Probably shouldn't comment, but don't the newer votec heads flow better, but they aren't, "1st Gen.", design heads?
rustbucket79
Post by rustbucket79 »
Class racing is all about specific casting numbers. You need to run the specific casting that your combo came with. (Unless there is an approved replacement)
vortecpro
Post by vortecpro »
pdq67 wrote: Tue Sep 29, 2020 9:21 pm Probably shouldn't comment, but don't the newer votec heads flow better, but they aren't, "1st Gen.", design heads?
The Vortecs do flow better, but there not a "early" head. A 441 head responds exceptionally well to mods, and will flow with a modified Vortec from what I've seen. Theres 441 castings that are better than other 441 castings.
tenxal
Post by tenxal »
Actually, the 327-275 combo is one of the least popular SBC's to build for Stock, especially with an automatic. The 350's (255/295/300 horse versions) and the 305's are the dominant SBC's in F/G/H class. The 350's and 305's are better than the 327-275, mainly in the area of torque and cylinder heads.
novadude
Post by novadude »
vortecpro wrote: Tue Sep 29, 2020 11:01 pm
How can you spot the "good" 441 heads? The engine I built for my Nova was a virgin '69 L65 250hp 350 with 441s. I went with Vortecs, but I've still got the 441s that came off a (high-mileage) running engine.
vortecpro
Post by vortecpro »
novadude wrote: Wed Sep 30, 2020 8:48 am
On the bottom of the head the casting number will be parallel to the intake runner.
tenxal
Post by tenxal »
Does icing down a cast iron intake manifold help?
-Can it hurt?
-Is there a better way to approach this?
-How do you address the QJet tendency to get rich at higher rpm?
Back to the pump to test fuels:
Testing fuels may require moving the cam around to chase any crumbs that may be there. This quick change setup lets us change cam timing quickly w/o messing with the balancer...a couple sips of coffee and it's ready for another pull:
No eye candy, here....yawn. :oops:
Do plug wires matter? :?: Maybe. :wink:
novadude
Post by novadude »
Looking very close at the pic of the secondary air bleed tubes... depth would matter, as does position of Holley Emulsion bleeds. Do class rules allow you to modify those tubes? I've got some thoughts....
chevyfreak
Post by chevyfreak »
tenxal wrote: Fri Oct 02, 2020 8:05 am
Still looks better than modern engine bays.
Chevyfreak.
Bowtie for life
novadude
Post by novadude »
Something I noticed on the engine bay photo above... a PCV valve. Seems like even mild street engine guys love to eliminate them and run open breathers (I don't agree, BTW... PCV = good). Really didn't expect to see a PCV on a stocker.
maxracesoftware
Post by maxracesoftware »
novadude wrote: Fri Oct 02, 2020 2:24 pm Something I noticed on the engine bay photo above... a PCV valve. Seems like even mild street engine guys love to eliminate them and run open breathers (I don't agree, BTW... PCV = good). Really didn't expect to see a PCV on a stocker.
on my Dyno tests ... theres a HP gain with modified PCV when using the relatively restricted flowing 4GC Carb 8)
MaxRace Software
PipeMax v4.50 Download Link : http://www.mediafire.com/file/4x3fwqub0 ... 0.zip/file
maxracesoftware
tenxal wrote: Fri Oct 02, 2020 8:05 am Does icing down a cast iron intake manifold help?
-Can it hurt?
... you mean during a Dragstrip Run ? , or just on a Dyno tests ? or both ?
i guess you tried black electrical tape mod on the QJet rear metering rod holes ?
and theres a custom gasket that does the same thing
MaxRace Software
