Jet size increase
408 Nova
Jet size increase
Post by 408 Nova »
How much do I jet up on an 8082-3 Dominator when taking a power valve out?
Then, on top of that, going from Turbo Blue (non-oxygenated) to VP -113 (oxygenated)?
1980RS
Re: Jet size increase
Post by 1980RS »
I usually go up 6-8 jet sizes. Better to go up too high than less and too lean.
mag2555
Post by mag2555 »
Jet remember that if you do not use the high tolerance Holley jets that going up to what you would think would be a 1 step fatter jet may not actually be richer then what you where running!
Sometimes you need to go up 2 jet sizes to really go up only 1 jet size!
408 Nova
Post by 408 Nova »
mag2555 wrote: Sat Sep 12, 2020 6:09 am Jet remember that if you do not use the high tolerance Holley jets that going up to what you would think would be a 1 step fatter jet may not actually be richer then what you where running!
I've got a jet kit from Holley. Those jets should be okay, right?
jmarkaudio
Post by jmarkaudio »
Start with 93 square, non oxygenated fuels.
Mark Whitener
www.racingfuelsystems.com
____
