Page 1 of 1
quadrajet carb for nitrous use
Posted: Tue Sep 15, 2020 1:54 pm
by rocketracer380
anybody running a rochester 4 barrel with nos 500 hp with 200 shot cheater plate
Re: quadrajet carb for nitrous use
Posted: Tue Sep 15, 2020 10:44 pm
by rustbucket79
Just a few NHRA stock and super stock racers
Posted: Wed Sep 16, 2020 4:22 pm
by 1980RS
As I look at it I have thought a Q-jet was not good for NOS at that carburetor favors the rear cylinders over the front. A fogger type system would work better IMO.
Posted: Thu Sep 17, 2020 3:55 pm
by shiftbyear
Does the carb loose some vacuum signal when the NO2 is shot into the manifold?
Posted: Thu Sep 17, 2020 5:21 pm
by lefty o
the carb isnt all that important while nitrous/fuel are being injected by a plate. someone probably has an accurate number, but amount of fuel/air a carb feeds while a plate is injecting nitrous drops by like 90%. i'd be more concerned with the quality of the manifold.
Posted: Thu Sep 17, 2020 9:02 pm
by rustbucket79
lefty o wrote: ↑Thu Sep 17, 2020 5:21 pm
Although I don’t have the CFM data In front of me from our dyno on a back to back NOS/NA comparison, I doubt there is much reduction in the airflow demand when the engine is, “on the bottle”.
Posted: Thu Sep 17, 2020 10:31 pm
by lefty o
rustbucket79 wrote: ↑Thu Sep 17, 2020 9:02 pm
look at the bscf from the carb go to near nothing. the engine is still demanding "air", but the bulk of it is not coming form the carb.
Posted: Thu Sep 17, 2020 11:21 pm
by rustbucket79
So if that’s the case then the turbine should show a subsequent reduction when on the spray. We don’t have many dyno customers with nitrous, but I will definitely isolate the fuel solenoids from the carb supply turbine to see what happens.
Of course I am referring to cheater style kits, maybe an engine running multiple big kits don’t flow much through the throttle body, I’ve never been involved at that level.
Posted: Thu Sep 17, 2020 11:52 pm
by Circlotron
That sounds like a 300 HP shot of nitrous is making 90% of the power. 333 HP total.
Posted: Fri Sep 18, 2020 8:48 pm
by rustbucket79
So I looked at 2 runs with a 540 BBC, NA and a 200ish shot of nitrous. The NA run drew 1087 CFM at peak, 957 CFM peak on the bottle. Looks to me about a 10 to 15% reduction in airflow through the carb on the bottle.
Posted: Sun Sep 20, 2020 2:46 am
by harry k
rocketracer380 wrote: ↑Tue Sep 15, 2020 1:54 pm
https://www.facebook.com/HKMotorsportsD ... 8669910632
Posted: Sun Sep 20, 2020 12:11 pm
by shiftbyear
rustbucket79 wrote: ↑Fri Sep 18, 2020 8:48 pm
Is there a carb jetting adjustment required when nitrous is used?
Posted: Sun Sep 20, 2020 9:46 pm
by rustbucket79
Not in the instance I mentioned
