Correct. For example, the additive packages of the following in parts per million (ppm)...ptuomov wrote: ↑Sat Sep 19, 2020 2:33 pm Thank you, RDY4WAR.
So the break in oil isn’t really about “wearing” the parts to shape, it’s more about adding a protective layer of anti-wear compounds to the parts?
My experience with break-ins is that with Nikasil played cylinders, one revs the engine to the redline three times and then it’s broken in — either the rings seal or don’t seal.
For flat tappet cams we run, the break-in may take longer and anti-wear substances may be more important. (We have to run high seated loads because of the turbo exhaust manifold space constraints.)
Zn = Zinc, anti-wear / anti-oxidant
P = Phosphorus, anti-wear / anti-oxidant
Ca = Calcium, detergent
Mg = Magnesium, detergent
Mo = Molybdenum, friction modifier
B = Boron, extreme pressure
Rotella T1 SAE 30
Zn - 1100
P - 1000
Ca - 2100
Mg - 10
Mo - 60
B - 160
Driven BR30 SAE 30
Zn - 2800
P - 2500
Ca - 350
Mg - 0
Mo - 0
B - 110
The break-in oil is more about what it doesn't contain than what it does.
I prefer a break-in with several heat cycles. Crank it up, go to 2000 rpm for 5 minutes, shut it off, and let it cool all the way down. About 90% of the break-in is already done. The rest if fighting for that last 10% through repeated heat cycles with varying load and rpm. Some people will say they don't do a break-in procedure at all. Others say they just hit the track and romp on it. These people get by just fine. It's not the proper way to do it, and they might see more blow-by or oil consumption throughout the engine's life that they may or may not consider to be "normal." Their engine may only be good for 600 passes now instead of 1000 passes, but it might not matter if they're pulling it to refresh it every 300-500 passes anyway. This can be why you'll see some conflicting view points.
It's kinda the same way with OEMs and why you'll see sometimes wide tolerances in clearances and other specs. The ideal case may let the engine live to see 500k miles while the worst case may only last to 300k miles. It doesn't matter in their eyes when the average car gets sent to the junkyard at 250k miles anyway.
