Edelbrock SBC Perf RPM - Any Good???
David Vizard
Post by David Vizard »
I have just finished porting a set of Edelbrock performer RPM heads for client. This gentleman bought these heads on a recommendation I had made over 20 years ago. However when I got the heads they didn't look a bit like I remembered them. To be honest I was a little apprehensive about getting any decent results from them. Can anyone tell me if the head castings have changed in the last 20 years or so. Also can I get some comments please on the flow test results shown below. Do they fall in line with what I could expect from these heads?
David Vizard
73c34me
Re: Edelbrock SBC Perf RPM - Any Good???
Post by 73c34me »
Following this closely. My SBC edel. Performer RPM heads are about 20 years old (64cc) I have ported them til their thin and hav 2.05” intake valves.
Walter R. Malik
Post by Walter R. Malik »
David Vizard wrote: Thu Oct 01, 2020 6:31 pm I have just finished porting a set of Edelbrock performer RPM heads for client. This gentleman bought these heads on a recommendation I had made over 20 years ago. However when I got the heads they didn't look a bit like I remembered them. To be honest I was a little apprehensive about getting any decent results from them. Can anyone tell me if the head castings have changed in the last 20 years or so. Also can I get some comments please on the flow test results shown below. Do they fall in line with what I could expect from these heads?
David Vizard
There are several different variations of the "Performer RPM" heads these days.
Over this summer I sold a 15 year old pair of original "Performer RPM" castings which I believe flowed about 250cfm @.500" on the intakes.
A few years ago got a pair of "Performer RPM" CENTERBOLT heads to port for a customer and they were not near the same intake port.
About 30 cfm less "out of the box".
73c34me
Post by 73c34me »
I am traveling for business, I cant access my records. but I do recall some flow numbers on the intake for my Rpms. Also, I never had them flowed straight out of the box, so I don't have a baseline... Intake port measured a 185 cc fluid pour out of the box. After porting they are 193cc fluid pour
@28" 200" 300" 400" 500" 600" Intake with a 2.05" intake
134 199 239 252 262 cfm
I dont recall the exhaust exactly, but I believe it is very close to David's numbers
73c34me
Post by 73c34me »
David. Would you be able to share the intake port measurements at the entrance, push and rod pinch? A gentleman on speed talk guided me on porting my heads,"Automotive Breath" I believe. I haven't seen him on here in a few years. He had great success with the Performer RPM heads with his preparation. Thnx. Jim
David Vizard
yes I can give you some dimensionl guidence here.
Port cc in 179 ex 72
Port entry 1.165X 2.0 - with corner rads factored in the CSA = 2.3 Sq Ins
MCSA 1.08 x 1.84 with .25 corner rads = 1.93 Sq Ins.
I have just finished a 1 hour youtube video. Lots of detail on the porting - includes port molds so you can better see what was done.
DV
73c34me
Post by 73c34me »
Thank you for sharing details. It is interesting that your port volume is smaller. Seems like a different variation of the Performer RPM line. I recall being surprised that mine measured 185ish cc, when the heads were advertised as 170cc. THis would have been in 2000 or 2001. I actually called edelbrock and spoke with a tech. person. He said to return them and they would replace them with the 170 cc head. The machine shop I was using said not to do so, that the bigger volume would be better for my 385ci, so i did. Thank you again for posting and sharing. Jim
RevTheory
Post by RevTheory »
Got a link for the video, David?
73c34me
Post by 73c34me »
refresh
PRH
Post by PRH »
A few years ago a 170cc version of the Performer RPM came out, which I believe was targeted at the small cube market. Two versions, HFT springs (61015), HR springs(61019).
They have 60cc chambers and come with 1.90/1.50 valves.
There is also the “Performer centerbolt” which is listed as 165cc, 60cc chamber, and 2.02/1.60 valves.
For the “normal” SBC heads, it appears that “E Street” and “Performer” heads have 185cc intake runners, and “Performer RPM” heads are now 195cc.
David Vizard
RevTheory wrote: Wed Oct 07, 2020 5:04 pm Got a link for the video, David?
Rev,
Not yet but posting will b soon - mayby as little as 2 weeks.
DV
mag2555
Post by mag2555 »
David, how is your recovery going, well I hope?
