Cast iron heads, surface rust
Any of you had decent results using a light solution of clr for rust removal on heads and blocks.
Re: Cast iron heads, surface rust
I put a rusty block in a container with very minimal amount of clr mixed with water and it came out better than I expected. Doesn't compare to thermal clean and shot blast but it was useable.
I use CLR for a lot of stuff like that. Works good while not being too crazy strong. Makes aluminum blocks and heads look much nicer also....usually. It can make freshly machined surfaces look a little funky if left on too long before rinsing or if in direct sun.Bill Chase wrote: ↑Mon Oct 05, 2020 3:19 pm Any of you had decent results using a light solution of clr for rust removal on heads and blocks.
I was gonna say it has phosphoric acid which is a rust converter but after a quick google looks like maybe not anymore https://en.wikipedia.org/wiki/Calcium_Lime_Rust
NAPA's Aluminum Brightener has a big dose of Phosphoric Acid.
Other brands similar
That's my next go-to after the CLR....but requires more caution than the CLR. I have had real good luck with it.
I just want to clean these heads up enough to mag and pressure test, if they pass that I will have them hot tanked.lance flake wrote: ↑Mon Oct 05, 2020 3:33 pm I put a rusty block in a container with very minimal amount of clr mixed with water and it came out better than I expected. Doesn't compare to thermal clean and shot blast but it was useable.
some DIY carwash pressure washers will let ya do greasy stuff; not allBill Chase wrote: ↑Wed Oct 07, 2020 5:17 amI just want to clean these heads up enough to mag and pressure test, if they pass that I will have them hot tanked.lance flake wrote: ↑Mon Oct 05, 2020 3:33 pm I put a rusty block in a container with very minimal amount of clr mixed with water and it came out better than I expected. Doesn't compare to thermal clean and shot blast but it was useable.
