T slot questions
shoedoos
Re: T slot questions
Post by shoedoos »
slightly off topic, OP where did you get those buttons mounted on your steering wheel?
mopardave
Post by mopardave »
That is a remote for gopro like camera.
shoedoos
Post by shoedoos »
cheers for that, I thought it may have been for a transbrake etc....looks nice and compact - what model camera do you have?
mopardave
Post by mopardave »
The remote is for my AKASO, but i don't use it any more. I now use a Gopro Hero 7.
mopardave
Post by mopardave »
The last test ride with the video i posted was pretty good. The twin carbs do almost everything my 1100 Dominator could do and the bawooo at the full throttle jab i think i can live with. After all, didn't the Quadrajets and the Thermoquads do the same thing from the factory? Think i will try a .030HB vs the current .028HB to bring the afr up closer to 13.0 at wot and call it good. I have had these carbs apart too many times and i'm getting burned out. Fell like i'm chasing my tail at this point. Thanks for all the info guys.
Geoff2
Post by Geoff2 »
If a 'bawooo' is a bog, then no TQs & QJs didn't do that when people who knew the carbs worked on them....
mopardave
Post by mopardave »
Not really what i would call a bog at this point. A flat spot milli seconds short would be a better description.
