Page 1 of 2
camel hump vs vortec
Posted: Tue Oct 13, 2020 2:06 pm
by Kambroziak
What would be a better combination?
Engine must be under 10:1 compression, max .500 lift cam . Flat top pistons 350 max .060 over. Holley 4412 carb and 1.375 restrictor plate. And production exh manifold. And any gm head except bowtie.
I have a set of camel hump heads with under cover porting from brezezinski and would have to run edelbrock torker ll intake #5001. Or I could run vortec heads with edelbrock performer EPS #2716. This will be in a 4000lb off road truck
Re: camel hump vs vortec
Posted: Tue Oct 13, 2020 3:50 pm
by ProPower engines
No comparison.
The vortec heads are better in every way unless you have free double bump heads and have to pay for the vortec's
If you flow the early GM heads and flow the vortec heads and compare the numbers.
The big difference is in the chamber shape.
Posted: Tue Oct 13, 2020 4:01 pm
by 1980RS
The Vortec's blow the camel humps away. I ran 11.50's with a 906 stock set and 10.90's @120 mph with a mild modified set of 062's that still use the 1.94 and 1.5 valves.
Posted: Tue Oct 13, 2020 4:55 pm
by falcongeorge
Kambroziak wrote: ↑Tue Oct 13, 2020 2:06 pm
https://www.castheads.com/cylinder-head ... ump-heads/
viewtopic.php?f=1&t=21448
Hmmm. so 228@.500 "blows away" 220-230@.500. Must be the new math...
Oh yea, flow bench numbers "don't matter". Post Modernism runs amuck...
Posted: Tue Oct 13, 2020 7:01 pm
by peejay
Flow is flow but velocity matters too, and the Vortec chambers are waaay better, they burn faster so you need less ignition timing.
Posted: Tue Oct 13, 2020 10:25 pm
by rebelyell
3 top techs w/ 3 same benches in same shop on same day will rarely record identical numbers.
+/- ten cfm is rather insignificant; and velocity is just as important.
Imitation is the sincerest form of flattery
Humps are good but if they were all that, GM would have never introduced vortec aka fastburn and none of their clones either.
JMO
Posted: Tue Oct 13, 2020 11:17 pm
by falcongeorge
peejay wrote: ↑Tue Oct 13, 2020 7:01 pm
rebelyell wrote: ↑Tue Oct 13, 2020 10:25 pm
JMO
Excuses. As the flow numbers prove, here isn't a hill of beans of difference, zero, zip, nada, nil, between this guys ported camel bumps and a pair of vortecs, and thats a FACT. And the camel bumps you guys are telling this guy he NEEDS to replace with a pair of vortecs are a SOLID 15 cfm better on the exhaust side. And yes, I have run AND PORTED both vortecs and camel bumps in the past. Normally, I could care less what kind of hogwash guys want to blather on about on internet forums (and that has escalated massively on here, lately, I have to check the header to make sure I haven't accidentally wandered on the HAMB), I just hate to see this guy being told he's going to see ANY gain if he runs out and buys some vortecs to replace these heads. Because he's not, and thats a fact, standard forum groupthink bullsh*t notwithstanding.
So OP, buyer beware. Groupthink is flattering to the ego of the speaker, and its totally free from behind the keyboard, but it gets expensive when you are buying the parts.
Posted: Wed Oct 14, 2020 12:02 am
by rebelyell
Valium was good; nowadays prozac
Posted: Wed Oct 14, 2020 5:21 am
by houser45
falcongeorge wrote: ↑Tue Oct 13, 2020 11:17 pm
JMO
Sorry, but you are wrong on this one, unless the double humps received epoxy/brazing work with major reshaping of the intake port the vortec head beats it. Even at even flow numbers. Which are not the whole story here. Chamber shape, spark plug placement and port velocity. More compression can be ran with the vortec head on pump fuel, just the fact that vortec will make as much power on 34 degrees of total timing on pump fuel should clue you in a little bit...
Posted: Wed Oct 14, 2020 6:13 am
by mag2555
Even if the double hump heads with there under cover porting flowed as much as the Vortecs. ( which they do not!) the Vortecs would still hold onto peak hp longer without nosing over due to there greater port volume and lesser redundant port area.
You then factor in the better burn of the chamber shape and its no contest at all as to which head is better!
Posted: Wed Oct 14, 2020 7:46 am
by vortecpro
Typically what I've seen the best 062/906 with zero shift can flow 240 @ around .500 lift unported and thats rare. Ported with a 1.940 valve I get around 260 CFM @ .550 lift. A 291/462 fuelie flows generally in the high 190s stock round .500 lift. Ported with a 2.02 valve still thick enough to use I get around 262 CFM but @ .650 lift. On the exhaust I get around 210 CFM, which I don't think I've seen on the Vortec head. With the fuelie I can run any piston I want. On welded fuelies (comp eliminator) I've seen much more flow. Super Stock 1.940 Fuelies flow 270 CFM with a 1.940 valve.
Some pictures of the last set of Vortecs I did.
28 inches, sealed 4.030 bore 1.940 valve.
.300 193
.400 234
.500 259
Exhaust was 180 @ .500
Posted: Wed Oct 14, 2020 8:11 am
by novadude
Mark... what is 'typical' for a set of unported 062s? Had mine on a bench with a 1205 radius plate and here's what we measured:
.300 189.8
.350 210.0
.400 227.2
.450 230.6
.500 227.8
Curious if this is inline with what you commonly find.
Posted: Wed Oct 14, 2020 8:30 am
by vortecpro
novadude wrote: ↑Wed Oct 14, 2020 8:11 am
.300 189.8
.350 210.0
.400 227.2
.450 230.6
.500 227.8
That looks familiar, BUT if theres core shift the port next to it could be down 15 CFM
Posted: Wed Oct 14, 2020 11:14 am
by falcongeorge
vortecpro wrote: ↑Wed Oct 14, 2020 7:46 am
.300 193
.400 234
.500 259
At last, someone else posting some hard data instead of mindlessly reguritating crap he read on other forums. And these guys are telling him he should replace his professionally cnc ported camel bumps with BONE STOCK vortecs, not based on the data, which says otherwise, but because "the internet says so".
So sad to see mindless groupthink taking over here, there used to be a preponderance of
thinkers here, this place used to be an island in a sea of internet ****, but I have noticed the erosion more and more. Has the real conversation gone over to the Hotpass boards exclusively?
As far as the chambers, angle mill the bumps and run the piston/head tighter, if you are really that worried about it. Tell you what, lets see one of these guys telling the OP that he has to chuck his ported bumps and start over donate the OP some dyno time, stock vortecs and eps against the Brzenenzski camel bumps and torker, optimise timing and jetting, for both combos and have at it. I don't even like the torker II that much, my guess is, it'll be a bloodbath, the vastly superior bump exhaust port will make the EP's torque advantage a wash, and the torker and bumps will walk all over the vortecs and EPS on top. FWIW, I usually see 255/260 from max effort (sleeved head bolt holes,no weld/epoxy) bumps myself, and I only consider myself a decent amateur porter.
Sure, IF you don't have a clue as to how to port heads, bolting on a pair of vortecs will gain over a pair of stock camel bumps. So what? I've ported them both, and I'd take a pair of ported bumps and a single plane over a set of stock Vortecs and an EPS any day of the week. Honestly this isn't even worth arguing about, its stupid to even be discussing this. I feel like I have wandered into the Steves nova forum or the HAMB. WTH has happened to this place?
OP, the stuff these guys are selling is cheaper by the truckload. You have a good set of heads there, and taking into account the two intake choices you presented (which I assume are dictated by the rules you run under?), they are the superior head. This stuff is expensive enough without wasting money on stuff that isn't going to do squat for you. I'm done here, there will be five more pages of bus jumpers spouting "vortecs is better, cause it says so on every forum" crap before this thread dies, thats how the internet works. Save your money and spend it somewhere where it will actually do you some good.
Posted: Wed Oct 14, 2020 1:38 pm
by Kambroziak
Yes the eps intake is what has to be ran with the vortec heads. And torker ll with any other gm head. Both must run the 1.375 restrictor plate. And holley 4412 carb. Once I figure out what heads will be used I can look for a cam.
