Long arm rockers
Little Mouse
Long arm rockers
Post by Little Mouse »
On intake valve would crowers long arm rocker with .090 back set the longer length to the valve make up for going to a higher ratio rocker in part at least to make it easier on a flat tappet cam ? Was thinking a lower lobe lift with as much size in the base circle and using more ratio be a better way to go on lift.
panic
Re: Long arm rockers
Post by panic »
Any ratio increase gives higher spring load on the tappet.
Little Mouse
Crower makes these long arm rockers from 1.5 to 1.85 im thinking id like to have 1.7 for just the intake and use 1.5 on the exhaust.
