Recommendation for Machine Shop / Engine Builder in CA?
- New Member
Can anybody recommend an excellent machine shop and/or engine builder in California?
I plan to pull the 327 out of my '65 Impala SS survivor soon, for a mostly stock rebuild (with a few upgrades). I haven't decided if I'll have all the machining done and then assemble it myself, or have the short block and heads professionally built and then handle the rest of the assembly.
I live about 50 miles north of L.A. but I'm perfectly willing to make a long drive for the "right" shop. By that I mean a place with a reputation for doing impeccable work and great attention to detail...you know the kind.
- GuysMonteSS
Re: Recommendation for Machine Shop / Engine Builder in CA?
I will second the recommendation for Mike Lewis
I would highly recommend Mike also!!
Tom
Tom
https://rpmengine.com/
Another excellent option in Rohnert Park. Nate Cutler / needforspeed66 here is a long time member and does excellent work that is second to none.
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
CPMotorworks,Inc.
http://qmpracing.com/shoptour.php QMP has got to be really close to you I’ve never used them a friend highly recommend them check out there sight.
Schaver? Hope I spelled that right.
https://www.enginelabs.com/features/sho ... gine-shop/
- New Member
Thanks for the recs guys. Many years ago I worked my way through college as a machinist and I know how hard it is to find somebody you can trust to do top-notch work. It's not getting any easier these days.
I've heard positive things about Mike Lewis from other sources so that's good. His shop is in NorCal, a 500+ mile drive but I'm OK with that especially since I'd probably only have to do a couple of round-trips. Going to a quality shop is a lot more important to me than convenience of location. I'll keep an open mind and still consider others, but Mike Lewis is sounding pretty good to me.
- GuysMonteSS
You can ship to Mike.AmericanPie wrote: ↑Thu Oct 22, 2020 3:37 pm Thanks for the recs guys. Many years ago I worked my way through college as a machinist and I know how hard it is to find somebody you can trust to do top-notch work. It's not getting any easier these days.
I can attest that he is very trustworthy.
He shipped everything but a block to me,all the way from California to Nova Scotia Canada.All the pieces arrived in the same condition as when they left his shop.
It would save you a ton of driving.
Guy
- New Member
I'll be needing the block to be completely prepped so I'd probably want to bring that up to him at the very least. That plus the crank, and maybe the stock iron heads...all that weight would add up.
I figure I'd be doing some driving. My daughter lives near Sacramento (on the way up there, sort of) so I could drop by and visit her.
Mike Lewis is a very qualified engine builder. However, if you are in Southern California, check out Jeff Ginter Racing Engines in Artesia. Phone 562.972.9763. Jeff has been in the high performance industry for several years.
Bill
SAE Member (30 years)
For a machine shop,Engine Supply in Santa Ana.He did Big Joes work before he passed.Tom
L&R Engines in Santa Fe Springs.
They do really good work and fair prices too.
They can do any level you want, just the machine work to the entire rebuild/restoration.
You might want to check out Superior Automotive Engineering in Placentia also. They did some work for me several years ago and did a very good job. The original owner's name was Joe Jill and now his son runs the place. They also built a 289 street motor for a friend that was dynoed at nearly 400 HP. They ported the stock heads and did all the machining, assembly and dyno tuning for him. I consulted Joe about 15 years ago on an engine I was building and he was super helpful. His son was working there then and he was very helpful and knowledgeable at that time.
65 Mustang FB, 331 custom built with 289 H beam rods and 383W piston, 282S cam, Ported Maxx 180s, T5z, 9" 3.89 gears. ~460HP@6500
2013 Corvette 427 Convertible daily driver
