i have dozens of pans. I just started cleaning up another 1 pc pan and i bought a felpro 1886 gasket. I had to zip cut off the dipstick extension in the block on the drivers side. There was a plug that was in the block so tight above the dipstick extension that i could not remove it. Just for laughs what do you guess this combo at for power ?
stock bore 350 with flat top 4 valve pistons (crank, rods and pistons are from a 94 LT1)
stock TBI heads with the swirl ports
TSP air gap intake (chinese knock off)
0-3310S 750 carb
comp 12-242-2 cam 224 / 230 .477/.480 110
1 5/8 headers
will this bunch of junk make 350 hp ?
Brian
SBC oil pan gasket help
Re: SBC oil pan gasket help
even w/ optimal quench & a little port cleanup; on pump gas, me thinks it'll be some 50-60 shy.
