SBC oil pan gasket help
prairiehotrodder
Post by prairiehotrodder »
I bought an 86 suburban with a 350 engine that turned out to be a reman or maybe even a GM new engine. I'm building it up for mild performance and found that its an oddball block. It s got a 1 piece rear main seal, milled and drilled for a fuel pump, milled and drilled for a roller cam, 4 bolt mains and it has provisions for a dipstick on both sides. the problem is i can't find the matching oil pan gasket. The oil pan also has dipstick kickouts on both sides. I can't find a name or number on the oil pan gasket that was in there. Anyone ever run into this before ?
Brian
the block is casting number 14101148
and stamped VB032971
rustbucket79
Re: SBC oil pan gasket help
Post by rustbucket79 »
The dual dipstick makes me think Targetmaster.
I know Fel Pro has a performance 1 piece pan gasket for the pre86 blocks, perhaps they have for your block too. What about the standard gasket for a roller block and plugging the drivers dipstick hole?
prairiehotrodder
yes it may well be a targetmaster. The pan must use a gasket with 2 dipstick kickouts. If i change pans then i should be able to use a more common gasket. I really want to use the pan i have though because i spent alot of time cleaning it and its ready to use and i need to buy a gasket anyways.
rustbucket79
I’ve never seen the late 350 block with double stick hole but I have seen a couple of the early blocks, obviously easier to deal with by purchasing both cork pan sets. :lol:
Have you checked with your GM dealer?
mt-engines
Post by mt-engines »
prairiehotrodder wrote: Fri Oct 23, 2020 6:26 pm I bought an 86 suburban with a 350 engine that turned out to be a reman or maybe even a GM new engine. I'm building it up for mild performance and found that its an oddball block. It s got a 1 piece rear main seal, milled and drilled for a fuel pump, milled and drilled for a roller cam, 4 bolt mains and it has provisions for a dipstick on both sides. the problem is i can't find the matching oil pan gasket. The oil pan also has dipstick kickouts on both sides. I can't find a name or number on the oil pan gasket that was in there. Anyone ever run into this before ?
Brian
I have a few grey rubber gaskets with steel that are dual dipstick. You can get them from engine tech, jegs, summit etc
you could also just buy a can of the right stuff.
prairiehotrodder
got a part number ?
sidestep
Post by sidestep »
Fel-Pro Oil Pan Gaskets OS34510T Has dipstick provision on both sides.
prairiehotrodder
sidestep wrote: Sat Oct 24, 2020 10:04 am Fel-Pro Oil Pan Gaskets OS34510T Has dipstick provision on both sides.
thats for a 2 piece seal engine. My engine is a 1 piece rear main seal.
6.50camaro
Post by 6.50camaro »
That gasket is for 85 and older 2pc rear main seal pans. I have a block with the same double dipstick side rails but is a 2 pc seal that uses that gasket but no roller provisions . It a Mexico block . Dan
sidestep
Post by sidestep »
My deepest apologies
Maybe this is a part number that will work
SBC CHEVY NEOPRENE OIL PAN GASKET 1pc RMS 86-UP FEL-PRO # OS-34500-R or P93173
prairiehotrodder
finally solved the mystery. I found a GM part number on my old gasket 14101149 which is discontinued and doesn't cross reference to anything. I'll call GM on monday and see if they happen to have any NOS laying around but other than that i have to change oil pans and use one with only the RH dipstick.
allencr267
Post by allencr267 »
Is it a 1 piece gasket, can you cut & paste a decent one, is the pan rail[block & sump] straight & smooth & clean?
BOOT
Post by BOOT »
sidestep wrote: Sat Oct 24, 2020 1:16 pm My deepest apologies
I almost did the same, cause I rem one that I have atm having both but before I even got the box down I realized it was for my 77 c3 with a 2 piece rm
Post by MadBill »
Here's one guaranteed to fit:
Loctite Instant Gasket: https://www.all-spec.com/Product/743913-30769
rebelyell
Post by rebelyell »
prairiehotrodder wrote: Sat Oct 24, 2020 5:26 pm finally solved the mystery. I found a GM part number on my old gasket 14101149 which is discontinued and doesn't cross reference to anything. I'll call GM on monday and see if they happen to have any NOS laying around but other than that i have to change oil pans and use one with only the RH dipstick.
Just a guess, but if you find gasket 14101149 maybe it'll be dirt cheap or very pricey.
How about a dirty junkyard Vortec pan and that FP OS34500R ...
mahle/clevite/victor OS32496B is equivalent to FP OS34500R but often much less $.
Both ATP 103033 & Dorman 264-100 offer new OE-replacement pans about $50.
