Centrifugal supercharger question
Re: Centrifugal supercharger question
Also have a huge power pipe inlet on it with big K and N filter in the passenger fender well.love this car10.9 quarter mile.aurburn diff with 3:55gears and manual transmission.had a ford Motorsport clutch in it,wouldnt hold it.put a center force in it problem solved.
Before you pull the trigger on a centrifical supercharger look into a or twin Rear Mounted Turbo / Remote Mounted Turbo System.. Essentually replaces the muffler in the exhaust system. A lot more space at the rear axle area. The long charge pipe to the front is essentually your intercooler.
Holley STS turbo systems.
The selection of the Turbo charger (size. A/R ) is a bit different
than a underhood turbo application.
I've had a Paxton on my 331 Ford for. 31 years 10 psi no trouble. At all just change the lube every couple years
