377 vortec
rocketracer380
377 vortec
Post by rocketracer380 »
4.155 bore 3.48 stroke 0 deck flattops 11.0:1 comp stock vortecs holley single plain and .230@ 50 .248@50 .510 in .525 ex with 1.6 im at .544 in .560 ex guides machined for added clearence 750 carb is 480hp too optimistic for combo forgot to mention 5.7 rods and 1/16 ring pack or am i better off with a 5.565 rod 406 with same cam and heads
408 Nova
Re: 377 vortec
Post by 408 Nova »
rocketracer380 wrote: Tue Nov 03, 2020 7:54 am 4.155 bore 3.48 stroke 0 deck flattops 11.0:1 comp stock vortecs holley single plain and .230@ 50 .248@50 .510 in .525 ex with 1.6 im at .544 in .560 ex guides machined for added clearence 750 carb is 480hp too optimistic for combo forgot to mention 5.7 rods and 1/16 ring pack or am i better off with a 5.565 rod 406 with same cam and heads
I'd say hp would be closer 425-450 going by similar combos I've seen.
Plus, I'd would run the 5.7 rods if you can make them fit. If they are stock type 350 rods, the rod bolts are longer than the rod bolts in the stock type 400 rods, so that the threaded end will hit the flanks of the cam on rod throws 1&2 and 5&6. So you'll either have to run a reduced base circle cam, or get a set of rods with a shorter rod bolt in them, or both.
I always have plenty of clearance with the Scat Pro Series rods. Just be aware that if you get a longer rod, you'll have to get a different set of pistons to correct the compression height (CH).
Re: 377 vortec
Post by F-BIRD'88 »
Id change the cam to a 248/248 on 106 lsa cam
or 248/251 106 cam (summit ct108)
rocketracer380
Re: 377 vortec
5.7 rod wont clear 3.48 stroke?
rocketracer380
Re: 377 vortec
the cam i posted is 107 lsa
rocketracer380
Re: 377 vortec
nice specs on that summit cam cheap too 89.99
skinny z
Re: 377 vortec
Post by skinny z »
rocketracer380 wrote: Tue Nov 03, 2020 7:54 am ... stock vortecs
Isn't the output going to be limited by the airflow of the heads? That is to say at about 225 CFM (by various accounts), the output is likely to reach 450 CHP at most?
Kevin
rebelyell
Re: 377 vortec
Post by rebelyell »
If you can swing it; 406".
400 crank, 6" rods, ~ 16cc - 22cc reverse dome pistons w/ about 1.125" comp distance (Mahle, Sealed Power, Wiseco/ProTru etc) and pay to have it all balanced.
Re: 377 vortec
Post by F-BIRD'88 »
Stock vortecs (062) flow 228 cfm.
Better if you port them with 2.02 valves. 250+ cfm
Re: 377 vortec
Post by F-BIRD'88 »
rocketracer380 wrote: Tue Nov 03, 2020 3:48 pm nice specs on that summit cam cheap too 89.99
These are made by Howards. There is a Howards # version and a Elgin # version.. same same.
If you can build as a 3.75 stroke 406 you are much better off. There are both -18cc and -21cc D dish pistons if you are building a pump gas 406 with 64cc heads.
skinny z
Re: 377 vortec
Post by skinny z »
F-BIRD'88 wrote: Tue Nov 03, 2020 6:24 pm Stock vortecs (062) flow 228 cfm.
Fair enough. So at 228 CFM, what's the most you can get?
Without some weird science thing that isn't available to mere mortals.
Seems to me, that 450 HP is about the limit regardless of the displacement.
Kevin
Re: 377 vortec
Post by F-BIRD'88 »
skinny z wrote: Tue Nov 03, 2020 6:59 pm
Something like that, yes.. Thats why I suggested porting with 2.02's to hit the target power.
skinny z
Re: 377 vortec
Post by skinny z »
F-BIRD'88 wrote: Tue Nov 03, 2020 7:38 pm
I'm following along on this as I have a set of aftermarket Vortecs from RHS that have been pocket ported and flowed at 255 (2.02/1.6 w/~ 175 cc port, 65 cc chamber).
The decision is the CID that they'll sit on.
Kevin
Re: 377 vortec
Post by F-BIRD'88 »
skinny z wrote: Tue Nov 03, 2020 7:47 pm
Bigger is better.
af2
Re: 377 vortec
Post by af2 »
F-BIRD'88 wrote: Tue Nov 03, 2020 8:11 pm
Bigger is better.
NO! How they hit the chamber is very important. Not being snotty just saying a well done Vortec will out perform a hogged out Masterpiece any day
GURU is only a name.
