Comparing Apples To Oranges! (Cams)
This is for a Chrysler 340 small block, but can apply to any make. So just comparing the specs and the likely characteristics of each based on them regardless of build details, they would be the same for either. I have access to two cams, a hyd and a sft. The hydraulic is an Isky 280 Mega with 280 adv duration, 232@ .050”, .485” in/ex lift 68 degrees overlap on a 106 LSA. The solid is a Mopar Performance 284 adv, 240@ .050”, .526” in/ex (.498”/..494” after lash) 74 overlap on a 106 LSA. Both would likely be installed at 102. Without knowing the durations at .100”, .200” etc what would you theorize the general differences to be regarding low end , mid range, and top end? I’m thinking not much difference?
Re: Comparing Apples To Oranges! (Cams)
i'd just skip it, and find a cam with lobes designed this century. cost difference between an antique grind, and a quality modern grind is insignifigant vs the benefits IMO.
Yeah, I should just skip the whole car then and buy a car from this century then.......
Don't take offense. He has a valid point.
? Valid point as in an answer to a question(s) I didn’t ask. If someone had each cam in their hand standing in front of the class at university and gave specs of each then asked for anyone to opine on how they would compare to each other, all else the same, and someone stood up and went on about lobes from this century and antiques.........ah geez never mind. LOL
Wow! Such a remarkably gracious intro! Perhaps you aced a Dale Carnegie course?
Ya know, you've joined-in on a site where there are lotsa rather knowledgeable, experienced guys; including a well-respected & successful cam designer-manufacturer.
Good luck in your endeavors. Out.
Well, the initial post was pretty straight forward and to the point, just looking for opinions on differences not recommendations unrelated. Didn’t realize that asking a specific question meant having to veer off course and humor the answers/recommendations given to questions I never asked. Interesting. I could have been really gracious and stated that I wasnt looking for any recommendations or advice from the get go but thought better of it.rebelyell wrote: ↑Sun Nov 08, 2020 4:24 pm Wow! Such a remarkably gracious intro! Perhaps you aced a Dale Carnegie course?
Which would you chose...and why?guicars wrote: ↑Sun Nov 08, 2020 10:09 am This is for a Chrysler 340 small block, but can apply to any make. So just comparing the specs and the likely characteristics of each based on them regardless of build details, they would be the same for either. I have access to two cams, a hyd and a sft. The hydraulic is an Isky 280 Mega with 280 adv duration, 232@ .050”, .485” in/ex lift 68 degrees overlap on a 106 LSA. The solid is a Mopar Performance 284 adv, 240@ .050”, .526” in/ex (.498”/..494” after lash) 74 overlap on a 106 LSA. Both would likely be installed at 102. Without knowing the durations at .100”, .200” etc what would you theorize the general differences to be regarding low end , mid range, and top end? I’m thinking not much difference?
- Paul
Not sure, short of trying both to see, Probably the solid...flip of a coin? Hmm, I’m thinking on the surface (without actually measuring or even plotting to determine other durations) the solid might offer a slight low/mid range advantage due to slightly shorter durations after lash (adv and @.050”) and that it has assuming slightly faster rate lobes, and a minuscule increase in lift, overlap it might pull a little stronger... but then the hydraulic has slightly more seat to seat and @.050”. Would be a toss up. If either was in the engine already I’d probably just leave it, seems to be a few who agree not much difference otherwise.pcnsd wrote: ↑Sun Nov 08, 2020 5:52 pmWhich would you chose...and why?guicars wrote: ↑Sun Nov 08, 2020 10:09 am This is for a Chrysler 340 small block, but can apply to any make. So just comparing the specs and the likely characteristics of each based on them regardless of build details, they would be the same for either. I have access to two cams, a hyd and a sft. The hydraulic is an Isky 280 Mega with 280 adv duration, 232@ .050”, .485” in/ex lift 68 degrees overlap on a 106 LSA. The solid is a Mopar Performance 284 adv, 240@ .050”, .526” in/ex (.498”/..494” after lash) 74 overlap on a 106 LSA. Both would likely be installed at 102. Without knowing the durations at .100”, .200” etc what would you theorize the general differences to be regarding low end , mid range, and top end? I’m thinking not much difference?
next thing your going to hear is "just put an LS in it".....with a powerglide.guicars wrote: ↑Sun Nov 08, 2020 5:16 pmWell, the initial post was pretty straight forward and to the point, just looking for opinions on differences not recommendations unrelated. Didn’t realize that asking a specific question meant having to veer off course and humor the answers/recommendations given to questions I never asked. Interesting. I could have been really gracious and stated that I wasnt looking for any recommendations or advice from the get go but thought better of it. :lol:rebelyell wrote: ↑Sun Nov 08, 2020 4:24 pm Wow! Such a remarkably gracious intro! Perhaps you aced a Dale Carnegie course?
no no, around here its a supercharger, and a 6bbl qjet! LS's are for common folk.oscaracme wrote: ↑Sun Nov 08, 2020 6:21 pmnext thing your going to hear is "just put an LS in it".....with a powerglide.guicars wrote: ↑Sun Nov 08, 2020 5:16 pmWell, the initial post was pretty straight forward and to the point, just looking for opinions on differences not recommendations unrelated. Didn’t realize that asking a specific question meant having to veer off course and humor the answers/recommendations given to questions I never asked. Interesting. I could have been really gracious and stated that I wasnt looking for any recommendations or advice from the get go but thought better of it.rebelyell wrote: ↑Sun Nov 08, 2020 4:24 pm Wow! Such a remarkably gracious intro! Perhaps you aced a Dale Carnegie course?
I'm the king of not getting questions answered and have simply stopped asking so I get it. Having said that, only maybe a couple of guys are going to know the real story between those two cams. We don't know the symmetry or duration at .200 or how well either one rolls over the nose or what.
One thing I like about solid-lifter cams is, depending on the lash ramps, you can fiddle with the lash to dial things in a little bit where with a hydraulic, you're stuck.
I agree with your choice. Not because I'm qualified to do so, but because in one of the software packages I use (EnginePro), changing only the camshaft type parameter from hydraulic to solid lifter results in a 18 HP increase for the solid in the "Base case 355 cu in engine" and raises Peak HP 150 rpm.guicars wrote: ↑Sun Nov 08, 2020 6:12 pmNot sure, short of trying both to see, Probably the solid...flip of a coin? Hmm, I’m thinking on the surface (without actually measuring or even plotting to determine other durations) the solid might offer a slight low/mid range advantage due to slightly shorter durations after lash (adv and @.050”) and that it has assuming slightly faster rate lobes, and a minuscule increase in lift, overlap it might pull a little stronger... but then the hydraulic has slightly more seat to seat and @.050”. Would be a toss up. If either was in the engine already I’d probably just leave it, seems to be a few who agree not much difference otherwise.pcnsd wrote: ↑Sun Nov 08, 2020 5:52 pmWhich would you chose...and why?guicars wrote: ↑Sun Nov 08, 2020 10:09 am This is for a Chrysler 340 small block, but can apply to any make. So just comparing the specs and the likely characteristics of each based on them regardless of build details, they would be the same for either. I have access to two cams, a hyd and a sft. The hydraulic is an Isky 280 Mega with 280 adv duration, 232@ .050”, .485” in/ex lift 68 degrees overlap on a 106 LSA. The solid is a Mopar Performance 284 adv, 240@ .050”, .526” in/ex (.498”/..494” after lash) 74 overlap on a 106 LSA. Both would likely be installed at 102. Without knowing the durations at .100”, .200” etc what would you theorize the general differences to be regarding low end , mid range, and top end? I’m thinking not much difference?
- Paul
