BBC heads question
Bob Hollinshead
Re: BBC heads question
Post by Bob Hollinshead »
I have the same tunnel ram, they made 5 different tops for it. The one with the largest plenum volume is a two piece design.
Pro question poster.
prairiehotrodder
Post by prairiehotrodder »
The new tunnel ram and vacuum pump seemed to help. Ran best of 9.166 at 148 mph. The mph is way up over last year even though the 60' is way worse. I'm quite happy that things are working good. If i can get the 60' to come around to where i think it should be, then a 9 flat should be possible. thanks to all my speedtalk friends for your help.
Brian
PRH
Post by PRH »
In May you had thought there was something wrong with it.
Find anything there?
prairiehotrodder
PRH wrote: Mon Aug 08, 2022 1:10 pm In May you had thought there was something wrong with it.
I took the motor apart and found nothing. On my third pass this saturday the motor started misfiring quite bad and slowed down 3 tenths. I checked everything and couldn't find anything obvious. I put in a set of spark plugs just because i had them at the track. That fixed it. I finally found that 2 of my spark plugs had a wiggle inside the porcelain. You could hear a clicking sound if you wiggled the end where the plug wire attaches. Its possible that those spark plugs were starting to fail the last time i was at the track however there was no noticeable misfire.
Brian
