The Pennsylvania 358 sprint car engine discussion
houser45
Post by houser45 »
I’ve never built one but I’ve been a little intrigued to know if anybody on here has built one or freshened one just Wanted to see some of the current and past trends on these engines were?
From my research it looks like the original ones were dry some ups roller cams with unported cylinder heads? Possibly 200 runner, but it looks now they can be fully ported.
Walter R. Malik
Re: The Pennsylvania 358 sprint car engine discussion
Post by Walter R. Malik »
houser45 wrote: Tue Nov 10, 2020 9:14 am I’ve never built one but I’ve been a little intrigued to know if anybody on here has built one or freshened one just Wanted to see some of the current and past trends on these engines were?
Sounds similar to the Fremont, Ohio 360, no wing sprinters.
houser45
Post by houser45 »
I believe it is the same as the “Ohio” sprints.
CamKing
Post by CamKing »
My brain is a little foggy, but if I remember right, first they were an unported head, then they allowed porting, but required a restrictive sized gasket between the head and manifold, then they went to a spec head.
All the classes, over the last 40 years, all seem to run together, so I could be way off.
enginebuilder44
Post by enginebuilder44 »
porting allowed must maintain org valve angle , no raised runner allowed any intake gasket allowed , no epoxy in ports 10.8 max cr
cgarb
Post by cgarb »
What HP are these engines currently?
dennis h
Post by dennis h »
1) What are the engine rules ? (would like to see rule book)
2) Wing or non-wing ?
3) Race track size ?
4) Corner entry and exit speeds ?
This is just for starters....
dennis h
enginebuilder44
most are 625-650 hp , 5x5 wing , 3/8 - 1/2 mile , rules are posted on lincoln speedway website
BlitzA64
Post by BlitzA64 »
The dyno shop I use has done a few of these, they were carbed alky I believe. Power ran about 585-600 from what I was told.
houser45
Post by houser45 »
enginebuilder44 wrote: Tue Nov 10, 2020 4:39 pm porting allowed must maintain org valve angle , no raised runner allowed any intake gasket allowed , no epoxy in ports 10.8 max cr
Yes. This is the ones I was reading about. What combos are guys using?
dennis h
Post by dennis h »
Lincoln rules state in part :
"Cast iron heads of stock configuration mandatory. Stock OEM valve guide angle
(Example - GM 23 degree) plus or minus 1 degree. No raised intake runners or spread
port exhaust. No modification to push rod area on intake port. Milling of heads permitted."
What is the translation of "no modification to push rod area on intake port" ?
Inside the port like an ASCS Series cylinder head that had a go-no go gauge or outside the intake port so you can't make them .150" wider?
dennis h
BlitzA64
Post by BlitzA64 »
Don't you love the folks that write the rules? :lol:
My assumption is if they are allowing you to port the heads it means no brazing or epoxy work allowed to make it wider than the original casting would allow but we all know about assuming
enginebuilder44
yes allowed to port but no braze or epoxy
