077 heads value
cv67
077 heads value
Post by cv67 »
Found a set on a shelf for 25 yrs never used, bare
Any idea what a fair price to pay is
Aware of their pitfalls but a mock ZL1 build could be fun.Those run best with 2.25 valves and some grinding?
Is a grand too much? Good deal?
Again untouched since new..what would hardware run me? Does ARP still make the extended studs?
Id need to helicoil the exh studs correct? Do they need valve jobs>
1980RS
Re: 077 heads value
Post by 1980RS »
To a restorer they are worth a lot. If I had a set I would just run them, now are these an original 68-69 set of heads or over the counter set? the date coded ones are where the money is on a set of heads like that.
cv67
Re: 077 heads value
Post by cv67 »
These are service replacements for the 074s the original ZL1 head
From what I gather they have a better exh ports and less porosity than then 074
cv67
Re: 077 heads value
Post by cv67 »
Pics show these are prisine as described have to make a deciison one way or the other
Fair price to pay for these? All I can find are old listings for used ones that had a lot of welding repairs done.
