BBC gear drive
Re: BBC gear drive
does anyone know if the milodon blown / injected gear drive can be used with a flat cover in a normal application ? I'm not blown / injected right now but may be some day.
Re: BBC gear drive
I am sure if can as long as the balancer clears and the timing pointer is located correctly and the WP pulley center line and the accessories line up you should be good.prairiehotrodder wrote: ↑Fri Nov 27, 2020 3:43 pm does anyone know if the milodon blown / injected gear drive can be used with a flat cover in a normal application ? I'm not blown / injected right now but may be some day.
You may need a spacer set for the WP and shim the alt. and PS pump but nothing guys have not done for the last 60 years anyway
- Dave Koehler
Re: BBC gear drive
If you see yourself going blown alky someday order the self contained unit that includes it's own cover with the center plate. You will be happier in the long run.prairiehotrodder wrote: ↑Fri Nov 27, 2020 3:43 pm does anyone know if the milodon blown / injected gear drive can be used with a flat cover in a normal application ? I'm not blown / injected right now but may be some day.
Re: BBC gear drive
Is the cam driven fuel pump better than a belt driven one ?Dave Koehler wrote: ↑Sat Dec 05, 2020 12:17 pmIf you see yourself going blown alky someday order the self contained unit that includes it's own cover with the center plate. You will be happier in the long run.prairiehotrodder wrote: ↑Fri Nov 27, 2020 3:43 pm does anyone know if the milodon blown / injected gear drive can be used with a flat cover in a normal application ? I'm not blown / injected right now but may be some day.
Are you suggesting to buy the milodon gear drive that has the flange to bolt on the fuel pump ? Can it be run with just a flat cover over it untill the need arises to use it as a fuel pump driver ?
- Dave Koehler
Re: BBC gear drive
1: In a blown app, yes. Ok to use NA also.prairiehotrodder wrote: ↑Sat Dec 05, 2020 2:18 pm1: Is the cam driven fuel pump better than a belt driven one ?Dave Koehler wrote: ↑Sat Dec 05, 2020 12:17 pmIf you see yourself going blown alky someday order the self contained unit that includes it's own cover with the center plate. You will be happier in the long run.prairiehotrodder wrote: ↑Fri Nov 27, 2020 3:43 pm does anyone know if the milodon blown / injected gear drive can be used with a flat cover in a normal application ? I'm not blown / injected right now but may be some day.
2: Are you suggesting to buy the milodon gear drive that has the flange to bolt on the fuel pump ?
3: Can it be run with just a flat cover over it untill the need arises to use it as a fuel pump driver ?
2: Yes
3: Yes. As the cover also incorporates cam end play the easiest thing is to make a little plate to cover where the pump mounts.
