BBC 540 build!!
Steve.k
Re: BBC 540 build!!
Post by Steve.k »
vortecpro wrote: Sun Nov 29, 2020 6:31 pm
F-BIRD'88 wrote: Sun Nov 29, 2020 6:22 pm Remember the dyno test is corrected HP to standard air.
The drag strip is real power at that moment uncorrected.
Also is thru the car drivetrain and tires. net rear wheel HP.
"as installed"
If I run 142.29 MPH @ 3580-3600 pounds how much HP is this?
1. Crankshaft
2. Rear whweels
Re: BBC 540 build!!
Based on the 700 hp engine running 125.5 mph in this Chevelle a 840 hp engine should run 132 mph in same Chevelle under same track test conditions.
Steve.k
Re: BBC 540 build!!
Post by Steve.k »
Alberta Canada. Our track typically has a da of 4100-5100
vortecpro
Re: BBC 540 build!!
Post by vortecpro »
Steve.k wrote: Sun Nov 29, 2020 6:37 pm Alberta Canada. Our track typically has a da of 4100-5100
Yes, but what track?
Re: BBC 540 build!!
Steve.k wrote: Sun Nov 29, 2020 6:35 pm F52F2503-2045-4DD1-9562-6D1F67D1AD48.png
"as installed"
1. Crankshaft
2. Rear whweels
The uncorrected real rear wheel hp can be calculated.
The gross corrected dyno tested brake horsepower can only be ESTIMATED from the data because the chassis
drivetrain tire lossetc etc are not exactly known.
Re: BBC 540 build!!
If you know yhe date time and location you can look up the historical weather data .
Steve.k
Re: BBC 540 build!!
Post by Steve.k »
vortecpro wrote: Sun Nov 29, 2020 6:38 pm
Central Alberta raceways. Are you around here?
Steve.k
Re: BBC 540 build!!
Post by Steve.k »
F-BIRD'88 wrote: Sun Nov 29, 2020 6:40 pm
Yes it’s listed on the track weather site.Air density online.
vortecpro
Re: BBC 540 build!!
Post by vortecpro »
Steve.k wrote: Sun Nov 29, 2020 6:41 pm
No, Ok 2900 feet elevation, 27.00 baro, 100 HP loss very easily.
vortecpro
Re: BBC 540 build!!
Post by vortecpro »
F-BIRD'88 wrote: Sun Nov 29, 2020 6:39 pm
1. Crankshaft
2. Rear whweels
I can tell you this, if I get into some 29.92 baro no head wind DA under 500 feet, I'am going to show corrected dyno HP running down the track in my race car.
vortecpro
Re: BBC 540 build!!
Post by vortecpro »
"as installed"
1. Crankshaft
2. Rear whweels
Re: BBC 540 build!!
vortecpro wrote: Sun Nov 29, 2020 6:48 pm
Take your engine and bolt it in this guys Chevelle inc his trans etc and see how good you do.
A well prepped typical bracket racer will eat about 50-60 hp.
This Chevelle is not.. I can tell by the numbers.. Or it weights more than #4000 all in.
Steve.k
Re: BBC 540 build!!
Post by Steve.k »
It sure is a difference. I bought a small block car that ran 6.95-7 in 1/8 from Columbus ohio. When we brought here best we could get was in 7.45-7.5 range. Thought I bought a dud for awhile.
vortecpro
Re: BBC 540 build!!
Post by vortecpro »
I think you understand now...........F Bird88 maybe not
vortecpro
Re: BBC 540 build!!
Post by vortecpro »
Steve.k wrote: Sun Nov 29, 2020 6:53 pm It sure is a difference. I bought a small block car that ran 6.95-7 in 1/8 from Columbus ohio. When we brought here best we could get was in 7.45-7.5 range. Thought I bought a dud for awhile.
A 27.00 baro is a killer, but just think we run in a 23.70 baro if you can believe that #-o
