Dyno HP Weather Correction Factor = (428.7 * 0.514) / 218.1
Dyno HP Weather Correction Factor = 1.010324622
Dyno HP Weather Correction Factor = (514.4 * 0.500) / 240.1
Dyno HP Weather Correction Factor = 1.071220325
HPCF : 1.010324622 -VS- 1.071220325
Larry,
Yes there is a big difference in correction factor from one sheet to the other sheet. But the correction factor for each sheet is almost constant is what I was trying to say.
Why the big concern over the opening area, The first thing to do is to get the events on the right LCA and both the cams you are using are not optimal for the apparent spec of engine you are running.
DV
David Vizard wrote: ↑Fri Dec 11, 2020 1:06 am
DV
Thanks David,
Personally I'd use more duration than the larger cam and tighter LSA. I'm curious on what you would recommend.
