HIGHEST HP N/A Small blocks out there!!
- af2
Re: HIGHEST HP N/A Small blocks out there!!
Am I wrong or were the PS trucks pushing 1100 with 330"? In the 90's
GURU is only a name.
"speed of the piston" .... super important , more important in many effects than most realize !by nhrastocker » Sun Dec 20, 2020 5:14 pm
One of the biggest considerations is the speed of the piston at different timing points.
- nhrastocker
Looks like BES could take over URE as no. 1.........But customer changed his mind to show the numbers.
At that date for a 358, 1000 H.P. would be a lot closer i do believe. Mark H.
Bob Book goe's to the top impressive!!
408” BRE/BH SB Mopar 1,253 HP, 3.07 hp/ci (Hemi)
466” CU/Marcella SB Chevy 1,244 HP, 2.67 hp/ci (ROX)
400” BRE SB Mopar 1,200+ HP, 3 hp/ci
400” ELIO SB Ford 1,200 HP, 3 hp/ci
457” CU LSX 1,200 HP, 2.62 hp/ci (2x4, Mozez/Slick Rick)
450” CU/BK SB Ford 1,185 HP, 2.63 hp/ci
396” Grant SB Ford 1,175 HP, 2.97 hp/ci
400” BRE/Dart LS Next 1,169 HP, 2.92 hp/ci
400” BRE SB Chevy 1,163 HP, 2.91 hp/ci
450” CU SB Chevy 1,140 HP, 2.53 hp/ci (Splayed Valve)
440” BES LSX 1,116 HP, 2.54 hp/ci
442” CU/BK SB Chevy 1,108 HP, 2.51 hp/ci (SB2)
400” Patterson SB Chevy 1,100+ HP, 2.75 hp/ci
401” Weurtz Bros SB Ford 1,085 HP, 2.71 hp/ci (D3)
435” SAM LSX 1,064 HP, 2.45 hp/ci
450” BES SB Chevy 1,064 HP, 2.36 hp/ci (Wedge)
- Caprimaniac
Are all above 10 000 RPM?
Sure, @what RPM and even max piston speed for all on the list would be interesting to see.
- midnightbluS10
Vengeance Racing built an 1100 hp, 9200 rpm 451ci LS with Mozez heads for this Corvette that set the NA half mile record.bob460 wrote: ↑Fri Jan 22, 2021 9:42 pm Bob Book goe's to the top impressive!!
https://www.roadandtrack.com/motorsport ... -v8-sound/
JC -
Conversation Started on YB
May 18, 2015
Started here Dec 2020.
Same topic.
May 18, 2015
Same topic.
Rowdy Yates if you have nothing good too say, don't say nothing at all.....go BITCH on yellow bullet.
