Hello,
I have parts to build a 4.155" bore x 3.625" stroke, with a 6.000" rod, 2.00" rod pin and 12:5:1 pistons.
However I am thinking of going with a 3.250 stroke crankshaft instead. Does anyone here know if the rods and pistons I have will work with the 3.250 stroke crank?
Thanks
Engine Combo Question
- New Member
Re: Engine Combo Question
Your pistons will not work. The rods may be able to be used over with the new crank if you get pistons that will match.
Or cut .1875 off the deck of your block. Better to do new pistons in my opinion.
Paul
Paul
