BBC pro dominater tr
Will it fit bb2 heads? srry so rude . hello im new =) trying to find the answer fast. selling some shop equip for cash and a tr setup to throw on myy 555 bbc build.
Ken
Ken
Re: BBC pro dominater tr
Yep, as long as your deck height is the same as the manifold casting , and they are both rectangle port. The ones I have seen were rectangle port, I am just not sure if they did an oval port intake or not. As always, buyer must do their own homework and inspection.
The deal hasent gone down so far. The numbers on the carbs indicate 600 cfm looks like vac secondary's. not sure how those would pan out. I was thinking fast would work mo betta. If this deal falls through. What might a suggested tr intake and cfm be for 555 w 10:5.1 w cam as follows
VALVE LIFT...........: .661 .668 CHECKING HEIGHT......: .015 ADVERTISED DURATION..: 291 297 VALVES TIMING @......: .050 VALVES OPEN..........: 17 68 VALVES CLOSED........: 57 12 DURATION @ 0.050.....: 254 260 LOBE LIFT............: .3890 .3930 ROCKER RATIO.........: 1.70 1.70 BANK ANGLE...........: STD STD CENTER LINE..........: 110.0 118.0 LOBE SEPARATION......: 114.0 CAM ADVANCE..........: 4.0
Yea the heads are Rec port Brodix (Big Brodie heads) Just not sure If Im gonna buy a new intake which one would be betetta.FC-Pilot wrote: ↑Tue Dec 22, 2020 1:00 am Yep, as long as your deck height is the same as the manifold casting , and they are both rectangle port. The ones I have seen were rectangle port, I am just not sure if they did an oval port intake or not. As always, buyer must do their own homework and inspection.
Ken
I think your right. Im not to happy w the choice. I called comp cams w car. weight. manual trans. flow sheet. cid and that I wanted to run a tr. I already have a set of Jessel sportsman alum shaft mount 1.7s =( maybe I pass the cam to a buddy for his 454 and buy another. {attachment=0]phpux9qwe_a23c25c19ee7ab4e8f60635b06cdefe9e9eb322e.jpeg[/attachment]
Is this street driven? If it is I think the duration is ballpark, a lobe with more lift would help it some. Maybe you got the wrong tech at comp cams.
Yes I will daily it. Looking at the Edelbrok tr fi w 2 throttle body's w injectors in the manifold. The tech was adamant about valve spring and roller lifter life and felt less lift would cause less lifter and spring wear
The tech was probably not giving you bad advice then. If its a daily driver, thats completely different than an occasional cruiser.
