rebelrouser wrote: ↑Sat Jan 23, 2021 10:30 am
I have been racing NSS, using 2, 750, federal mogul AFB's for almost 30 years. I have O2's on my car and have had a couple different engine combinations on the dyno. My car now runs 9.70's 139 mph. All the AFB's I have ever used lean out at high RPM's. To help with this issue I have done the following which made it better. First AFB's have a very small float bowl, if you take the top off the carb, and just lay a float in the chamber you will see what I am talking about. My son is a mechanical engineer, and in discussing this issue with him, his work had a computer program for calculating flow and other variables in hydraulic systems. I gave him the specific gravity of the fuel I was using, and all the dimensions of the fuel system, and the demand for fuel we used was .5 lbs per horsepower. His results, said the needle and seat orifice and the orifice in the pressure regulator were the restrictions in the system. I changed out the pressure regulator, got new large orifice needles and seats, and drilled the carb bodies for dual feed. It still leaned on the top end but it was an improvement. I did notice that it became very consistent after the modifications, most of the time slips were nearly identical, unless the driver screwed up.
There are some older threads about the newer AFB clone carbs and the boosters etc. on speed talk, look them up, lot of good info. My next step was to put the carbs on a flow bench and use the velocity probe in the jet to measure how hard the venturi pulls on the jet. By polishing and trimming on the boosters, I got all eight to pull the same amount. Next step was to lighten the secondary weights, and measure how much vacuum it took to open them, and again grinding and swapping spare parts until I got exactly equal secondary opening. Also on the secondary opening, the amount the blades open can really affect the amount of pull on the jets, if the blade opens too far and goes slightly over center it really messes with the booster signal. I say this because lots of guys are cutting off choke air horns for more flow, and are letting the secondary blade open too far because they cut off the material that used to stop it. I also changed the way I cut off AFB airhorns, because of the turbulence you get on a flow bench around the air bleeds and top of the boosters if you cut them too short.
Then in reading the older speed talk posts on AFB's I made some thin sleeves to extend the primary boosters into the narrowest part of the venture. That also gave it another step in the booster which my idea was to improve fuel atomization. Not sure what helped the most, or if I even did everything right, but those carbs are worth 35 HP on my dyno over my old ones. And guess what, they still lean out some on the big end, so I am chalking it up to the small float bowls.
And just on my car, I have found it likes more ignition timing at the launch, and less on the big end, so I have an old MSD retard that works off rpm, to retard the timing at 5,000 rpm. When I first put it on, it was worth a tenth. I need to see if it still works with my current combo, that was 4 engines ago.
I know guys that are running NSS cars into the 8's with AFB's and I have seen their carbs apart and they don't have a ton of modifications, I am sure they lean out as well, I don't see how they could not. My car runs through 1st and 2nd right at 12.5, then in 3rd , it leans to 13 to 1 as I cross the finish line, if I richen it to run 12.5 across the line it slows down, and plugs read rich. On the dyno the air fuel remained pretty constant, but the length of the pull was not as long as a run, and of course the load on the engine is different than a pass down the dragstrip.
