removing rust from cam lobes?
econo racer
Post by econo racer »
I looked at selling a few new camshafts I kept in my office and they have light rust with some pits. Will emery or scotts brite clean them up. I might have 30 cams they keep poppin up. there are some good grinds in there. :D Also found a nice 402 crank shaft. I have to sell everything as I will be starting a new job hopefully in March.
travis
Re: removing rust from cam lobes?
Post by travis »
Fine steel wool works well for light rust. Pits might be a problem though
CamKing
Post by CamKing »
If the lobes have pits, they will likely fail during break-in.
rustbucket79
Post by rustbucket79 »
CLR spray does wonders for surface rust, just be sure you’re outside with the garden hose and compressed air and WD 40.
jeff swisher
Post by jeff swisher »
Cams with rust can be reground but I would not run them.
If it is just on the journals and light rust I have no issues removing that rust with a wire wheel and running them
Too many variables to answer that question with a yes/no/maybe. Flat tappet or roller? Solid or hydraulic? Stock/street or race? New or reground? Warranty or as-is-where-is-take-your-chances-swap-meet?
In the obsolete engine business, it's usually low spring pressures, low RPM and that's the only cam in the known world, so it gets cleaned and run; minor rust pits on cast iron lobes were no issue.
At the other end is a tool steel cam going in a 9,000 RPM NASCAR engine having to last 500 miles for the series championship.
