SADI core hydraulic roller...which distributor gear?
travis
Post by travis »
Some say cast iron, others say steel is ok, and several manufacturers push their poly distributor gears. I have no interest in the poly gears...so which material would be correct?
EDC
Re: SADI core hydraulic roller...which distributor gear?
Post by EDC »
On the small block Ford combinations I do, we recommend the factory roller cam gear or the coated steel ones from Crane.
Never had an issue especially when coupled with a small oil spray hole drilled into the lifter bore core plug.
Nil Satis Nisi Optimum
Walter R. Malik
Post by Walter R. Malik »
travis wrote: Sun Jan 10, 2021 5:54 am Some say cast iron, others say steel is ok, and several manufacturers push their poly distributor gears. I have no interest in the poly gears...so which material would be correct?
NOT ... plain cast iron.
Ductile iron nitrided gears are best for SADI ... or composite material.
Several companies offer them for different applications and have their own "brand" name for them.
rebelyell
Post by rebelyell »
melonized dist gear aka melonite
