Stock LS lifters for cam
Therriaultper
Post by Therriaultper »
I have a BTR cam for a LS the cam lift is 560 the question is can I use stock lifters with this cam ? Any information would be great thanks
BOOT
Re: Stock LS lifters for cam
Post by BOOT »
Did you ask BTR?
What is the use?
Are the lifters new or used?
More details may get you more interaction.
jed
Post by jed »
I'll get push back on this but I worked at a LS shop that built 2 to 4 long blocks a week used I think Eaton lifters
and had virtually No engines come back with lifter problems. The engines were 600 hp to 1500hp street and race turbo and aspirated. Camshafts lifts ranged .600 to .825. RPM were 6000/9000.
I would not be affrade of stock LS lifters.
CamKing
Post by CamKing »
Run these GM lifters
GM 12499225
