machinable welding rods
jimmyhemi
Post by jimmyhemi »
hello i use to years back get a arc welding rod and could cover the piece up weld the hole up drill and tap new threads. every thing get now welds way to hard to drill and tap. does anyone know what kind they where.
ProPower engines
Re: machinable welding rods
Post by ProPower engines »
So what are you welding?? Or what part of the engine are you repairing??
Can't you use a time sert to fix a oversize hole??
vwchuck
Post by vwchuck »
It was probably a brazing rod.
Dan Timberlake
Post by Dan Timberlake »
Regular old 6011 shouldn't be too bad "as deposited" on mild steel.
https://selectrode.com/datasheets/6011.pdf
Consumer grade drills and taps still might squeak and dull quickly.
Good drills and taps that have rolled around a tool box togethe are probably already too dull.
If a cast iron part was being welded the diluted metal and especially the original "heat affected" iron might be between HRC40 and " file hard."
BOOT
Post by BOOT »
Not what you asked but would a Time-Sert work?
Chris_Hamilton
Post by Chris_Hamilton »
You don't specify what material you are welding so I'm assuming it's steel. 7018 would work well. Just a general purpose mild steel rod. I've repaired plenty of farm equipment with those rods and drilled and tapped holes afterward. Stuff was always breaking.
Don't quench anything post welding. quenching hardens steel. Also you can temper a hard weld simply by re-heating the area to at least straw (color) blue would be better, and letting it cool slowly. If it's outside and windy you could cool it gradually by using a torch and simply moving the torch progressively away from the work. And again if you have been quenching post weld, don't quench.
