I’m currently finishing up the bottom end on my 385 build and I wanted as much input as possible as far as my combination is concerned
350 over 40
Eagle crank 3.75 stroke
Scat 6in rods
SRP flat tops (11:1 with 64cc head)
750 holley DP
Professional Products single plane intake
3500-7500 rpm range
Comp Cam -12-900-9
630/630 lift
252/258 @50
106 lobe separation
3500-6900 rpm range
RHS 235cc heads or Brodix Track 1 221cc?
Both are available
Turbo 350
3500 stall
411 gear
Will be going in a 3500lb G body full interior street car
What type of power do you think engine combo will
Produce? Will be going to the race track and also Will be driven on the street occasionally.
Any suggestions and inputs are appreciated thanks
385 SBC Build
Re: 385 SBC Build
should do 525-550hp depending on head chosen. just my thoughts, a 235 head is a BIG head on a 383 and you would be better served by a good 210-220 cc head for a street car .
Re: 385 SBC Build
With your 3500 stall i would use the Brodix head. However which head you choose your combo would benefit the most from a good 8” torque converter approx. 5200-5500 rpm stall speed.
- New Member
Re: 385 SBC Build
Thanks for your responses. Is the cam choice a decent one or could I make a bit more power by changing it since it isn’t installed? Any head recommendations? Trying to stay away from AFR since that’s what everyone my way is running.
Re: 385 SBC Build
Are you going to be running 1/4 or 1/8 mile mostly? I go along with Monza on the track 1's over the 235's ,along with more stall. I know from past experience when I went from 3500 - 10" to a 5300-8" I picked up about 3 tenths in the 1/8 with no other change. I just purchased a set of RHS 220's for my 376 bracket engine . I'll see how they work out. Good luck Dan
- mt-engines
Re: 385 SBC Build
Id use the RHS235 and a cam that is at least 10 degrees larger with more lift. should be in the 600s. on a side not i think i have that exact cam you posted for sale.
Re: 385 SBC Build
Where would peak tq and hp on the dyno from your experience, how far past peak would you recommend shift point 500 rpm - 1500rpm?mt-engines wrote: ↑Mon Jan 11, 2021 2:27 pm Id use the RHS235 and a cam that is at least 10 degrees larger with more lift. should be in the 600s. on a side not i think i have that exact cam you posted for sale.
With that CSA on the 235 head would need plenty of converter and gears,at a guess you would be operating above 7500 rpm at the track
