BLP Main body BX4
Robban 54
BLP Main body BX4
Post by Robban 54 »
Has anyone tried BLP BX4 Main body retrofit kit?
https://blp.com/cart/images/BX4RK_Uncoated.jpg
Robban
ClassAct
Re: BLP Main body BX4
Post by ClassAct »
Yes. I have a BX4.
Robban 54
Post by Robban 54 »
Any difference from a regular Holley?
ClassAct
Post by ClassAct »
No comparison, the BLP is just better.
BradH
Post by BradH »
At one point on here I posted asking if anyone had back-to-back tests of comparable configuration (venturi size & booster type) 4150 carbs based on traditional "HP" main body vs BX4-type main body. At the time nobody provided anything, so I'm still waiting to hear of quantifiable improvements from the new design.
I'd certainly expect a BX4 is "better" in a number of areas, but how that translates into dyno / on-track performance still seems unclear. I may do my own testing in the future, but that would be pretty far down the road given what else is a higher priority for me. Thx
ClassAct
Post by ClassAct »
BradH wrote: Mon Jan 25, 2021 9:23 am At one point on here I posted asking if anyone had back-to-back tests of comparable configuration (venturi size & booster type) 4150 carbs based on traditional "HP" main body vs BX4-type main body. At the time nobody provided anything, so I'm still waiting to hear of quantifiable improvements from the new design.
I haven’t done back to back yet. I might later this year, but it depends.
Robban 54
Post by Robban 54 »
I got my BX4 today.
Will return with assembly and test drive when the snow is gone and the temperature is above freezing.
BradH
Post by BradH »
What venturi size & throttle bore is yours for? Thx
Robban 54
Post by Robban 54 »
1,560+1,750
jmarkaudio
Post by jmarkaudio »
Size for size all else equal probably little if any difference for most. Great for one you need to upsize, and you can chose the booster that can impact performance. Plus the price for billet is only a little different than the castings available.
Mark Whitener
www.racingfuelsystems.com
____
Robban 54
Post by Robban 54 »
Only the look does probably 10 horsepower. :D
Now it is at least assembled and test started.
Test drive will have to wait until spring.
Bob M
Post by Bob M »
Have you had a chance to run the car with the new main body yet? Any feed back would be appreciated.
Robban 54
Post by Robban 54 »
Have not been able to drive that much yet.
It's still pretty cold.
But the low speed seems to be about the same.
I have increased the main jet a few steps but it's still too lean.
There seems to be a gap between low speed and high speed.
Robban
Mike Laws
Post by Mike Laws »
Robban 54 wrote: Tue Apr 13, 2021 1:11 pm Have not been able to drive that much yet.
Robban
Venturi/throttle bore ratio is not ideal which is causing the need for more fuel. The gap between low and high speed is understandable. Your best bet is to put an aggressive annular booster in it. (Mark has some.) Gotta get that air moving to pull fuel.
Mike Laws Performance
Tuner
Post by Tuner »
Mike Laws wrote: Tue Apr 13, 2021 6:24 pm
Robban
Isn't it a simple shame so many carb people apparently haven't read NACA TR49 and similar related historical research papers that are available free for the time to learn. #-o
